Can't Remove This Faucet Cartridge - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-20-2013, 06:34 AM   #1
Can't remove this faucet cartridge
Hi all,
I have a single handle tub faucet that has been kind of crazy with the temperature for a couple months (you have to turn it every which way until the water is warm). Now it won't stop leaking (don't worry I turned off the main water before I started). I've been looking all over the web for info on how to fix this, but all of the info I find says I need to remove a clip or a nut that is holding the cartridge in place. My faucet has neither. There is no washer either. Can you help me identify this cartridge and how to remove it? Thanks.
Cybrie is offline   Reply With Quote
Old 05-20-2013, 06:53 AM   #2
DIY staff
Rewards Points: 7,174
I do not recognize the brand---but I would guess that the large nut is holding in the cartridge.( right behind the white part)
Have you removed it yet?
Old 05-20-2013, 07:14 AM   #3
Hi, thanks for answering I tried twisting that nut, but it seems it's a part of the rest of the cylindrical silver piece. That's not budging either.
Old 05-20-2013, 07:22 AM   #4
DIY staff
Soak it in penetrating oil (PB Blaster is good.)
That is what holds the cartridge in place---A plumber might be along soon that will recognize the brand--then you will be able to google up a parts drawing.
Old 05-20-2013, 07:40 AM   #5
okay pb blaster it is...thanks for the help so far.
Old 05-20-2013, 09:57 AM   #6
Rewards Points: 13,468
Really should be using a tool like this.
http://www.bing.com/images/search?q=...lectedIndex=79
It works like a deep well socket.
It will allow you to but equal pressure on the fitting.
You are turning it counter clock wise right?
Old 05-21-2013, 07:08 AM   #7
Okay I got this resolved now...I wasn't aware that I could call the landlord and he would send someone to fix it..thanks a lot though. A little embarrassing, but thanks. lol
Old 05-21-2013, 07:11 AM   #8
DIY staff
You got it fixed---sometimes the telephone is the best tool in the tool box!
Old 05-21-2013, 07:11 AM   #9
Master Plumber
Javiles's Avatar
Rewards Points: 994
WHAT ! all those wasted keystrokes.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 05-21-2013, 07:17 AM   #10
Haha! I have to agree.
Oh yes, it's a cruel thing...the way life can cheat you out of keystrokes that way.
The Following User Says Thank You to Cybrie For This Useful Post:
oh'mike (05-21-2013)
Bath Faucet Cartridge Installation sobro Plumbing 7 06-14-2012 04:35 PM
Leaking faucet..replaced cartridge mrmerck Plumbing 2 03-28-2012 09:23 PM
how to remove plastic pipe on bathtub faucet beverly78 Plumbing 3 08-06-2011 08:06 PM
No resistance in faucet lever after cartridge was changed Mikeel Plumbing 10 07-25-2011 06:45 PM
problem: remove bath faucet rjw_mpwr Plumbing 2 06-05-2010 02:55 AM
