Old 04-10-2008, 09:58 AM   #1
Can't reinstall shower valve properly
Ran into an issue with no hot water in my shower. We have bad sulfur water and have issues with the sulfur clogging filter, screen, valves, etc. elsewhere in the house so I proceeded to take the shower valve apart. Heavy brass casting housing the single handle mixer valve. Shower only unit, no tub. On the brass casting it looks like it is stamped SYMMONS. I can't find any other branding on the unit at all. Seems to be good quality. the mixer valve itself is a cylinder with sets of hole drilled around it. Sure enough, a bunch of those holles were plugged up tight with black junk. cleaned it all out and went to put everything back together. Here's where the trouble starts.
At first, when I threaded the valve assembly back into the body, I could barely turn the valve at all. I've tried threading it in with the valve fully open and with it fully closed. I finally got it to work somewhat but it still doesn't seem right - very stiff, not a lot of hot water and leaking water through the valve threads. I think there is an orientation/"timing" to the whole thing that I'm not gettign right, but don't know if there are alignment marks I need to find or what. I attached a pic of the assembly if that helps. I can post pics of any portion that will help. Help!
ptoneil is offline   Reply With Quote
Old 04-10-2008, 02:18 PM   #2
Journeyman Plumber
Ron The Plumber's Avatar
Better quality pictures would help out.
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
Old 04-10-2008, 09:08 PM   #3
I'll try. the image size restirction for attaching to this thread make it really hard. I'll take it back apart and get some shots of the components.
Old 04-10-2008, 11:05 PM   #4
Send a message via AIM to Marlin
Try www.imageshack.us
Marlin is offline   Reply With Quote
More On This Topic
Hey man, Don Goldman back with Expert Village and we are outside. We are working on this leaky shower project. The reason I am outside is because we've got to shut the water off. You don't want to take that valve off without turning off the water. So the... Read More »
Hey everybody it's Don Golden with Expert Village and we are back outside. Why is that? Because we are almost done with this project. The shower, the cartridge is in and now all we've got to do is turn the water back on and see how it is working. Now I... Read More »
Hey gang, it's Don Golden here for Expert Village and the water is running and we've got to turn it off. I think we pretty much fixed our leaky little problem in here. So what we did was we took this old housing off and replaced our old leaky cartridge... Read More »
Water Bleed in Shower Head
Water Bleed in Shower Head by Expert Village
Hey people, Don Golden here for Expert Village. We are still in the shower and we've got some work to do. We've taken off the valve cover here and before we get to work on this job, I want to bleed some of the residual water that is still trapped in the... Read More »
Hey I'm Don Golden with Expert Village. We are on our way to a dry shower when we want it to be dry and a wet shower when we want it to be wet. It's not going to leak anymore because I have replaced the cartridge. We had just installed the new cartridge... Read More »
Pressure Balance Shower Valve Hammer glenn60 Plumbing 7 06-17-2009 09:30 PM
How to change the shower valve? amdspitfire Plumbing 17 04-06-2008 10:05 PM
New Shower Valve Installation wagnersr Plumbing 1 04-03-2008 09:11 AM
Question about shower valve? Rick Bruner Plumbing 3 03-23-2008 11:09 PM
aging symmons temptrol shower valve v240969 Plumbing 1 01-01-2008 06:24 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
