Old 12-26-2011, 09:56 PM   #16
retired elect/hvac/plumb
plummen's Avatar
Can't level shower drain for mortar shower pan install
Its all about the conductance of the pipe and transfer wires,or transfer of water in this case anyway!
plummen is offline   Reply With Quote
Old 12-26-2011, 10:01 PM   #17
jproffer's Avatar
HAHAHAHAHA...
jproffer is offline   Reply With Quote
Old 12-26-2011, 10:03 PM   #18
plummen's Avatar
Couldnt help myself!
Old 12-26-2011, 10:20 PM   #19
how much do you recommend to cut off? is there a special tool for it?
Can't level shower drain for mortar shower pan install-p1010028.jpg   Can't level shower drain for mortar shower pan install-p1010026.jpg   Can't level shower drain for mortar shower pan install-p1010033.jpg
Mjolnir is offline   Reply With Quote
The Following User Says Thank You to Mjolnir For This Useful Post:
plummen (12-27-2011)
Old 12-26-2011, 10:24 PM   #20
yes they make an inside pipe cutter ..from hd, lowes.or hardware. about 12-15.00 well worth it...good tool to have. cut off enough to install cuppling then the strainer to proper height...
The Following User Says Thank You to ben's plumbing For This Useful Post:
Very Strange Shower Drain Problem MattWhite Plumbing 12 05-21-2011 12:53 PM
Shower drain gasket install tricks dbrew Plumbing 6 03-10-2010 10:20 PM
Installing basement shower drain atilla137 Plumbing 5 09-03-2009 12:54 PM
Maxx Shower Walls Install on Metal Studs? atilla137 Plumbing 2 11-21-2006 07:17 PM
shower drain nomoney Plumbing 4 05-19-2006 10:27 AM
