Can't Get Water To Go In Hotwater Heater - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-14-2013, 08:55 AM   #1
can't get water to go in hotwater heater
Would anyone know how to change an inlet vavle on a hotwater heater?
All pipes are hooked up to electric water heater and the cold water will not go in.
diana4526 is offline   Reply With Quote
Old 03-14-2013, 08:59 AM   #2
Rewards Points: 13,978
#1 Please go back and add your location to your profile. Just go to Quick links and edit.
What makes you think it's the valve?
Sure the pipes not frozen?
Got a picture so we can see what your seeing?
Old 03-14-2013, 09:07 AM   #3
Lightfoot's Avatar
Rewards Points: 272
did you open a hot water faucet to let the air out of the tank and the water in?
Be sure not to turn on the water heater till all the air is out and the tank is full.
Flashlight: A cylindrical container used to store dead batteries
Lightfoot is offline   Reply With Quote
Old 03-14-2013, 09:39 AM   #4
recieved a working hot water heater from a friend when they changed over to a tankless and mine blowed out. The water heater is a kenmore roto swirl. I keep opening the valve on the side for pressure and none is built up.
Old 03-14-2013, 10:08 AM   #5
One reason we needed a picture is to see if you have the old style gate valves.
Lots of times they just will not shut off or the stem inside snaps off so it's stuck in one position.
Replace it with a ball valve, problum solved.
May be able to even use a Shark bite valve for an easyer install.
plumberinlaw (03-15-2013)
Old 03-14-2013, 10:14 AM   #6
Can you tell me where this vavle would be?. And If I haven't already told you thank you very much for your help
Old 03-14-2013, 10:22 AM   #7
No way anyone here's going to know where it is without seeing it.
It was suppost to be right there at the heater on the cold side.
SOme many not even have one of it was plumbed wrong so you have to shut off water to the whole house to change a heater. Not a great plan.
If someone changed the heater, how did they shut the water off to do it?
Sure hope the powers off, if not and there's no water in the tank then plan on buying a new heater the elements have melted by now. Only takes about a min. to melt them.
Old 03-14-2013, 10:30 AM   #8
Mr. Joe the electric is off........
Old 03-14-2013, 10:41 AM   #9
Plumber
TheEplumber's Avatar
Rewards Points: 802
In order to get good suggestions from us- walk us through the tank installation process.
Where are the valves located the turned off the water supply to the heater?
Have you confirmed that they are open?
Do you have cold water at your faucets?
Old 03-15-2013, 01:57 PM   #10
I installed a gas water heater two years ago, working fine. I turned the cold valve off just before heater to work on the Humidifier. Turned the water on and nothing coming out of the hot water faucet in the sink. The gate on the Chinese made valve did not move stayed in the closed position!
Ball valve all the way now
Hardway is offline   Reply With Quote
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
How to properly drain and flush a hot water heater? speedster1 Plumbing 9 04-17-2012 09:55 PM
no water at sink after water heater removal rebelbull Plumbing 2 07-19-2011 12:37 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
Water heater pressure relief valve confusion Flt_Simulation Plumbing 4 07-11-2009 10:02 AM
