Can't Get Water Flow To Return To Bathroom Sink - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-01-2011, 09:22 PM   #1
Can't get water flow to return to bathroom sink
while trying to address a small leak from the trap of our bathroom sink, my husband turned off the water at the shut off valves. when he turned them back on only a small trickle of water will flow through the faucet. it feels like there is no pressure in the pipes. we have water flowing everywhere else in the house. we are at a loss...any ideas what could be causing this?
ahalford is offline   Reply With Quote
Old 08-01-2011, 09:26 PM   #2
Lightfoot's Avatar
Rewards Points: 272
edit. i should have read the p.s.
Lightfoot is offline   Reply With Quote
Old 08-01-2011, 09:33 PM   #3
oops...there is an aerator- thanks for asking
The Following User Says Thank You to ahalford For This Useful Post:
lovekeke (06-04-2012)
Old 08-01-2011, 09:34 PM   #4
thanks...problem solved!
Tags
bathroom , shut off valve , sink , trap
Pressure drop across water heater, low hot water flow HVAC_NW Plumbing 2 01-17-2011 10:43 PM
PEX pipe and sharkbite slowing water flow? Snav Plumbing 1 04-09-2010 03:32 PM
Hot water faucet pipe thumps then flow slows down. DIY-Indy Plumbing 9 07-15-2009 11:09 PM
Low Hot Water Pressure btennant Plumbing 4 12-09-2008 09:31 PM
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 07:32 AM
