Can't Get New Hot Water Tank Pilot Lit - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-01-2011, 07:19 PM   #1
Can't get new hot water tank pilot lit
I have a new 50 gallon AO Smith Hot Water Heater just installed. It has an electronic pilot, but we cant get it lit. Any suggestions
aad724 is offline   Reply With Quote
Old 06-02-2011, 06:00 AM   #2
Rewards Points: 1,216
Loosen the gas connection at the water heater untill you smell/hear gas and hook it back up wait five mintues and try again there's a lot of air in the new lines mixed with the gas you have to get the air out.
COLDIRON is offline   Reply With Quote
Old 06-02-2011, 07:43 AM   #3
Rewards Points: 1,578
Coldiron: Not knowing mechanical skill of the poster and making that recommendation is dangerous IMO. If it is not properly retightened and checked for leaks, kaboom! Also, venting gas into the room could be dangerous if there is a source of ignition.
Aad724: If it is new, call back the installer and have them light it. It could be a defective igniter; I had a brand new gas dryer installed and the igniter was broken during shipping.
bob22 is offline   Reply With Quote
Old 06-02-2011, 07:54 AM   #4
Maybe he installed it with a friend and if it was installed by a Contractor by all means he should call the Contractor back for a relight and troubleshooting. This is a diy site and I would make the same recomendation to anyone, the guy just needs a little info and by loosening the fitting for a few seconds to get the air out of the line it shouldn't be any problem. Check posts on hot water heaters and see how many times the same recomendation was made.
Tags
hot water tank , plumbing
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
H2OwTo Pressurized Water Tank problems Gary5579 Plumbing 4 12-11-2011 06:25 AM
Lost Hot water pressure brile Plumbing 11 11-28-2010 02:59 PM
water borehole question joeuser General DIY Discussions 2 04-18-2010 10:33 PM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 08:36 PM
