Old 02-09-2012, 01:05 PM   #1
Question
Can't get this caulk off!!
We are installing a new direct-to-stud shower surround, keeping our old base. I've removed everything down to the studs on the walls, but I cannot get the caulk to come off. I've used the worthless tool that comes with the caulking kit I have, I've tried a box cutter/utility knife - nothing. I mean, not a sliver, not a crack. I have a Dremel rotary tool (which is fantastic) - can I get some advice on wether I should try using it for this stubborn stuff?
Katy H Jordan is offline   Reply With Quote
Old 02-09-2012, 02:06 PM   #2
retired elect/hvac/plumb
plummen's Avatar
Picture,are you sure its caulking and not construction adhesive?
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 02-09-2012, 02:14 PM   #3
I know for sure it's caulk on two of the three sides, as some of it came off when the tile came down, and what's left is clearly caulk and is coming off a little bit at a time. What's at the back wall looks the same, it's just much more stubborn. I tried to get a couple of pictures but my camera is worthless. If it is construction adhesive v. caulk, is there any good way to get it off withouth damaging the base itself?
Old 02-09-2012, 02:22 PM   #4
plummen's Avatar
If its construction adhesive like pl400 or something like that youre in for a workout,maybe a sander even
If its that old dried out poly seam seal stuff,I really hate it!
I personally like painters caulk,yeah I know lots of people dont like it.
Anyway its easy to put on just get your thumb wet and smooth it out,and cleans up with soap/water.
And if you have to recaulk it every couple years you can scrape it off easy enough
Silicone on the other hand is tough to clean up and smears really easy in my book anyway
Old 02-09-2012, 02:26 PM   #5
*sigh* I knew this was going to be more elbow grease.
When I redid our powder room last year, I used clear silicon caulk on the vanity. It was definitely smear-happy (and smells so strong!!), but I really like that it's pretty much invisible. They used painter's caulk on our guest-bathroom tub along the floor. We've only been here about 2.5 years, but so far so good.
Old 02-09-2012, 10:20 PM   #6
Doing it myself
Alan's Avatar
sometimes a wood chisel works really well for a caulking scraper.
Just be careful with it.
Journeyman Plumber
The Following User Says Thank You to Alan For This Useful Post:
plummen (02-09-2012)
Old 02-09-2012, 10:50 PM   #7
Master Plumber
Javiles's Avatar
Get a commercial heat gun, be very very careful apply heat slowly then work it up, again be very careful.
Experience is Knowing what to do next, Skill is knowing how to do it
Javiles is offline   Reply With Quote
Old 02-10-2012, 07:24 AM   #8
Super Moderator
A multi-tool works wonders on hard caulk---
Old 02-10-2012, 11:17 AM   #9
There are also some caulk remover products that will soften up, and sometimes dissolve, the caulk. Depending on the caulk, you'll probably have mixed results. I had some that softened right up. Another section a foot away would have gone faster with a chisel. Also a final warning, if you use one it'll get messy.
a_lost_shadow is offline   Reply With Quote
Does mold grow on or in uncured caulk ? TheITloveswood Flooring 11 09-08-2011 06:28 AM
What type of Caulk to Use Einhorn General Discussion 19 08-21-2011 03:50 PM
How to Clean Up Caulk Mess on Driveway Left By Construction Crew ToolbeltGal Building & Construction 6 09-25-2010 05:36 PM
Caulk Frustration j4ino Building & Construction 5 09-29-2008 08:03 AM
recaulking: cleaning out old caulk questions adamc Painting 6 09-19-2008 06:30 PM
