Can't Get Bonnet Off Delta 1400 Series Faucet - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-20-2013, 09:13 PM   #1
Can't get bonnet off Delta 1400 series faucet
Apparently the cartridge had a small leak for quiet awhile, and with all the hard water here in Las Vegas, calcification has gotten into the bonnet threads. So far I have not used any liquid persuasion methods. I put one wrench on the housing so it wouldn't try to turn, and the other on the bonnet. While holding the housing wrench to keep it from moving, I pulled as hard as I thought safe to do without breaking/modifying the housing, and the bonnet will not budge (and yes, I am turning it counterclockwise lol).
So, I know what the problem is (junk in the threads) but I'm not sure the best way to dissolve that junk. What would the experts suggest?
I've replaced one of these cartridges before, but on that one there was no problem getting the bonnet loose. This one is a bear lol.
strad is offline   Reply With Quote
Old 08-21-2013, 05:17 AM   #2
raylo32's Avatar
Rewards Points: 1,294
You should post this in Plumbing section of the forum....
Live long and prosper.
raylo32 is offline   Reply With Quote
Old 08-21-2013, 07:20 AM   #3
Rewards Points: 44
Could try soaking it with vinegar overnight or use a propane torch and heat it. Heating it will probably ruin the bonnet's finish.
Dan
djlandkpl is offline   Reply With Quote
Old 08-21-2013, 09:02 AM   #4
Haha I don't care what the finish looks like! It's under a chrome trim piece anyways so it doesn't matter.
Old 08-21-2013, 10:28 AM   #5
Try tapping the nut lightly many, many times with a hammer.
ask tom is offline   Reply With Quote
Old 08-21-2013, 12:11 PM   #6
Wd40 let it soak for a little and should come off..if not cut it off without damaging the valve body. A grinder with a cutting wheel carefully cut and break away..
Peppe1019 is offline   Reply With Quote
Old 08-24-2013, 12:36 PM   #7
Well, it did eventually come off. Here's what I did:
took a paper towel and wrapped it around the housing/bonnet, strapping it on with a rubber band. Soaked that all day periodically with white vinegar, and sprayed into the threads with PB blaster. The next day, (frustrated) had my handyman buddy come over, and I held the pipe wrench on the housing while he used his very large set of pliers on the bonnet. It did eventually come off with a lot of protest. Then the cartridge didn't want to come out of the housing, so that got busted in half, and a screw went into the half still stuck in the bore. Pulled on the screw with a small pry bar and popped the half out. Cleaned up the threads with a wire brush, cleaned out the housing real well, greased the bonnet threads, and put it back together with a new cartridge. SOOO glad that thing come undone lol. I had visions of retiling a portion of the bath tub after replacing the faucet!
The Following User Says Thank You to strad For This Useful Post:
TheEplumber (08-24-2013)
Old 08-24-2013, 07:50 PM   #8
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Keep twisting till it snaps off and replace with a Moen faucet!
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Problem removing handle off of Delta Monitor 1400 series tub/shower faucet kcinsj Plumbing 35 10-22-2015 04:02 PM
No flow from Delta Monitor 1400 faucet after reinstallation StubbornFaucet Plumbing 14 10-09-2015 10:00 PM
Trying to fix Delta 1400 series tub faucet jayfisher Plumbing 1 11-09-2011 06:00 PM
Need help fixing leak to Delta Monitor 1400 series shower/tub faucet star987 Plumbing 16 05-01-2011 05:26 PM
fixing delta faucet 1400 series skcong Plumbing 2 07-03-2010 10:20 PM
