Can't Get Below Frost Line - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-10-2010, 05:21 PM   #1
can't get below frost line
frost line in my area is 36 in. i can only get down about 12-16 inchesi need to run hot and cold water about 50 feet to my shed. how do i keep lines from freezing?
mcknuggett is offline   Reply With Quote
Old 05-10-2010, 05:26 PM   #2
Keep the water off and drained in freezing weather or dig deeper?
bluejeans is offline   Reply With Quote
Old 05-10-2010, 07:06 PM   #3
Civil Engineer
Rewards Points: 4,938
Insulate and heat trace the pipes if it is allowable under local code.
Old 05-10-2010, 07:39 PM   #4
How about running the water lines through 3" ABS pipe and pull a heating cable in there, with them!
If the heating cable goes bad, you can pull it out and replace it with a new one!
Old 05-10-2010, 09:25 PM   #5
Rewards Points: 410
What are you running into past 12-16" ?
High Gear is offline   Reply With Quote
Old 05-11-2010, 01:34 AM   #6
That's what I'm wondering too... My first inclination is to say "buy a bigger pick". Actually, the ground around my yard was so hard that I bought a 5# railroad pick to do my digging.
Another option is renting a trencher. That should be able to get you below 2.5 feet with a little hand digging to get the last few inches.
The other thing, the dirt is easier to dig if it has some moisture content. If it's been a while since you got a good rain, you may want to use a garden hose to MOISTEN (not wet) the trench for easier digging.
HooKooDooKu is offline   Reply With Quote
Help My Admiral Refrigerator is leaking water Cuwillis Appliances 10 03-25-2014 08:21 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
electric line and gas line couch potatoe Electrical 17 09-30-2008 10:43 PM
Condensate Line schott HVAC 17 06-02-2008 03:16 PM
frost line farrington135 Building & Construction 2 05-16-2007 05:35 PM
