Cant Get An Auger Past A Possible Tee Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-01-2013, 07:09 PM   #16
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 2,866
DJ.... I know those warranties are often a piece of junk... but can't you hold them to it.... and then get to see how it was ultimately fixed.?
I hope you did not have to pay the first guy.
Best
Peter
MTN REMODEL LLC is online now   Reply With Quote
Old 07-01-2013, 09:56 PM   #17
DonikaJackson's Avatar
Idk. This is our first home and first experience with having to fix things like this. It did cost 60 bucks, that we paid for absolutely accomplished.
DonikaJackson is offline   Reply With Quote
Old 07-01-2013, 10:12 PM   #18
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
You or a plumber may be able to run a camera down the pipe to see what's clogging the pipe. They have camera's that will run all the way to the street.
It should be able to show you exactly what your dealing with.
sublime2 is offline   Reply With Quote
Old 07-01-2013, 10:21 PM   #19
DJ.... Read your warranty contract... now that is no fun... but it's got to be esier than snakeing through a clogged main. Generally, the contract will provide the company make a covered repair, with a deductable ($60 apparently in your case) and should provide who the deductable is to be paid to. You still have a right to have it fixed.
Old 07-15-2013, 11:42 AM   #20
My husband pulled the toilet and got the auger to the clog. Tree roots. But all is clear.
Old 07-15-2013, 11:50 AM   #21
Plumber
TheEplumber's Avatar
Rewards Points: 684
That's good news.
If you can afford it- I'd go the next step and rent or hire a sewer camera and see what shape your line is in. You may have got just enough of the roots to open it. They will come back and as they continue to invade your line, they damage the pipe joints
Old 07-15-2013, 12:34 PM   #22
Rewards Points: 6,652
What you need is a cutter, not an auger. You also need to flush Roebic Foaming Root Killer after getting the roots cut, then repeat that in every 18 months. If you have an outside stand pipe, it makes it easier to get the six inch cutter in there, to clean out all the roots.
Tags
auger , plumbing , sewer
Sewer Back Up/ Pipe Relining Question newbinca Plumbing 9 05-10-2013 12:23 PM
Need advice on rusted pipe problem silencer Plumbing 16 12-02-2012 08:59 AM
PVC or CPVC pipe cement steve3847 Plumbing 7 11-17-2012 05:50 PM
How to stop sump pump discharge pipe freezing??? relbeig Plumbing 8 11-12-2012 12:03 PM
corrugated drainage pipe, how to couple? bubbler Landscaping & Lawn Care 5 05-28-2012 10:13 AM
