-   -   Can't fit slip nut because of dishwasher line (http://www.diychatroom.com/f7/cant-fit-slip-nut-because-dishwasher-line-21212/)
Brettson 05-19-2008 07:15 PM
1 Attachment(s)
A few days ago the slip nut connecting the strainer in my kitchen sink to the pipe corroded and split. I bought a new slip nut to fix it but I can't fit it on because the dishwasher line is welded to the pipe (see picture)! Any suggestions on how I can attach the
strainer to the pipe and make my kitchen sink usable again.
Thanks,
Brett
clasact 05-20-2008 05:07 AM
I think your going to need a new pipe to the strainer that has the nut already on it and a dishwasher connection
JAYBOY 01-13-2011 03:11 AM
Jayboy
I had a similar problem. I bought a plastic slipnut and a stainless steel 3" band clamp. I cut the tabs off the slipnut, then made one vertical cut completely thru the nut.
I used a dremmel with a cutoff wheel, a fine tooth jigsaw should be ok.
That let me pull the ends apart enough to get it over the pipe. I then put the s.s. Band around the nut and tightened the screw.
I had a functional slipnut without disassembling the pipe.
The main thing is to get all the plastic "sawdust" off the threads so they match.
rjniles 01-13-2011 04:20 AM
Get a new tail piece with a dishwasher connection. Available in PVC for a few dollars.
Bigd3129 01-13-2011 07:34 AM
It seems you'll have to first disconnect the dishwashing supply line and (clamp), then take off your tail piece, then you can put your tail pieces metal lock nut on over top, don't forget your tail piece's plastic washer too. then you should be good to go.:)
cabinetman 01-13-2011 07:41 AM
+1. I agree. Just unclamp the DW line. Remove the piece from the bottom of the sink, and get a new PVC one at any home center. They are available in metal also if you wish. I would stick with PVC. And yes...only a few bucks, and 10 minutes if that.
the_man 01-13-2011 07:51 AM
when you get the new plastic one, make sure that you get the one that has a 5/8 tee instead of the 7/8 version. also, get a new tailpiece gasket for it to avoid the second trip to the store :laughing:
LateralConcepts 01-13-2011 08:40 AM
Yeah don't try to fix what you have. Just replace it. All you need is a dishwasher tailpiece. If your p-trap is metal too, I'd just pick up a new PVC one as well. Don't mismatch parts. (i.e. plastic to metal)
http://www.homedepot.com/Plumbing-Pi...atalogId=10053
