Can't Find 1/5 To 2" Traps. - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-16-2009, 09:51 PM   #1
Rewards Points: 682
Can't find 1/5 to 2" traps.
I was trying today to replace a trap I had to remove to get to a stubborn clog. The trap is old and odd, it looks like a 1/5" to 2" trap.
Lowes didn't have any (mild surprise) and the local plumbing store didn't have any either (big surprise). Are these things that hard to find?
I was able to reuse the old trap, but it wasn't easy.
darsunt is offline   Reply With Quote
Old 09-16-2009, 09:57 PM   #2
JDC
Plumbing Contractor
JDC's Avatar
Rewards Points: 262
I'm confused. Do you mean an 1-1/2" to 2" trap? If so, use a 2" glue trap with a 2X1-1/2" reducing bushing. Once its reduced to 1-1/2", you can use a 1-1/2" desanco (trap adapter).
JDC is offline   Reply With Quote
Old 09-17-2009, 11:11 AM   #3
Rewards Points: 682
Yes, I mean a 1.5" to 2" trap.
Your right, I probably could have used a 2" trap and used some kind of adapter. I didn't think of that.
But are there any 2" to 1.5" traps still out there?
Old 09-17-2009, 12:18 PM   #4
Registered User
Termite's Avatar
You might luck out but I doubt it. Fixtures that require a 2" drain can't be necked down to 1-1/2" so it wouldn't make much sense to make it. You can easily use a PVC bushing or fernco and neck it down though...Just not the trap itself.
Can't find good laminate comparison anywhere cpsilo1 Flooring 3 03-20-2011 05:49 PM
Bestion solution for insulating a 2" hot water pipe ? Wookai HVAC 14 01-15-2009 07:59 PM
Hi, Newbie for this site to find way to remove toilet valve wfang Introductions 2 01-04-2009 04:27 PM
find switch to control outdoor light fixture CaymanAg Electrical 1 07-10-2005 09:43 PM
New to find a contractor - Northern NJ jhirsch1 Building & Construction 2 03-23-2005 09:24 PM
