Can't Figure Out Where The Toilet Is Leaking??? Interior? - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-12-2010, 07:36 PM   #1
Can't figure out where the toilet is leaking??? Interior?
I have a toilet that has recently started leaking at the base along the tile. I replaced the connecting hose from the wall outlet to the toilet. It is definately not leaking from there.
I suspect it is leaking from inside the workings of the toilet or the toilet bowl. I don't see any cracks. The toilet is aprox 10 years old.
Does anyone have any suggestions? Is it fixable or just cheaper to hire someone to replace the entire machine?
Leaking just at the base a little where the toilet meets the tile in the front area:see the glossy wet area near the tile and toilet?
CostcoMan is offline   Reply With Quote
Old 04-12-2010, 07:50 PM   #2
the Musigician
DangerMouse's Avatar
Hi and welcome.
Does it leak more if you flush it? If so, it's likely your wax ring is not sealing properly.
Good news? An easy and inexpensive fix. Usually only a few dollars. VERY DIYable!
DM
Old 04-12-2010, 08:13 PM   #3
Rewards Points: 1,088
Can it really be leaking from the wax ring if there's a bead of caulk between the base and the tile floor?
I would check the gasket between the tank and the toilet.
handy man88 is offline   Reply With Quote
Old 04-12-2010, 08:18 PM   #4
tank sweating?
The older I get the better I was
Old 04-12-2010, 08:20 PM   #5
the Musigician
Possibly, though a wet backside would be a sure giveaway.
Wiggle the tank gently, if it's loose, you'll know quickly.
Water can seep easily past a silicone caulk line if grout is weak.
DM
Old 04-12-2010, 08:41 PM   #6
The leak does increase a little each time you flush it. So I am thinking it is the the floor to toilet gasket that you speak of.
The two bolt covers that point to the tile are glued on fake. The installer just filled them with caulking and stuck them on. Not sure why. I just pulled them off.
The toilet is bolted towards the wall. I got one loose and waiting till tomorrow on the other. Right now the toilet is caulked so tight everywhere that it won't budge from its place.
Old 04-12-2010, 09:45 PM   #7
fabrk8r
fabrk8r's Avatar
CostcoMan...the two bolts you are referring to are what holds the WC (water closet/toilet) to the flange.
Before you try to move the WC shut the water supply off at the angle stop (valve attached to line going to bottom of tank) and remove the supply line from the tank. Then flush the WC to drain the tank. To remove the remaing water from the bowl quickly pour a bucket of about 1-1/2 gallons of water into the bowl...this will force almost all of the water out. Now you can remove the two hold down nuts at the base of the toilet.
There are a lot of good online tutorials about replacing wax rings for DIY.
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline   Reply With Quote
Old 04-12-2010, 11:00 PM   #8
Thanks fabrk8r and the rest of the posters for the help.
I have to wait until my house guest leave than I am going to try to take a crack at this
Old 04-13-2010, 12:09 PM   #9
I've once had a leak that seemed like it was the bowl but was actually the tank... more specifically the bolts that hold the tank on the bowl. The leak was running down the back of the bowl where I couldn't see it, but would see it on the floor.
The bolts that hold the tank on the bowl should have some rubber grommits (thick rubber washers) to form a seal. Check to make sure that is not the source of your leak (cheap fix if it is).
I've also fixed a leak where the problem was a warn out rubber seal between the tank and the bowl. Leak only happened when the toilet was flushed... but that one was a little more obvious.
HooKooDooKu is offline   Reply With Quote
The Following User Says Thank You to HooKooDooKu For This Useful Post:
CostcoMan (04-13-2010)
Old 04-13-2010, 01:44 PM   #10
Thanks HooKooDooKu. I checked all those areas carefully with food dye and say nothing.
I decided to pull up the toilet. Not an easy task with all that careful caulking and tight fit. Looks like my seal to the wall pipe is shot. It feels like a sticky mess of glue right now
Old 04-13-2010, 02:30 PM   #11
the Musigician
that sticky 'glue' is what's left of your wax ring.
DM
Old 04-13-2010, 02:47 PM   #12
Oh...hahah..I get it now that I touched it.
How do I get the paint texture to match the wall once the top thin paper dry wall layer has been pulled off? I am trying touch touch up the paint area before I re-install. I already removed all the old painting and caulking from the toilet.
Just having a hard time bringing that wall paint up another .05mm to match the rest of the wall. Thanks
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 08:52 PM
Toilet leaking at the base on floor John24689 Plumbing 4 10-19-2009 09:03 AM
Toilet jpark Plumbing 18 01-05-2009 08:12 AM
HELP - Seriously leaking toilet JAR Plumbing 3 11-03-2008 05:28 PM
Water leaking into septic pipe below toilet Gramps Plumbing 1 09-14-2008 10:54 PM
