-   -   Can't figure out where the toilet is leaking??? Interior? (http://www.diychatroom.com/f7/cant-figure-out-where-toilet-leaking-interior-68930/)
CostcoMan 04-12-2010 06:36 PM
I have a toilet that has recently started leaking at the base along the tile. I replaced the connecting hose from the wall outlet to the toilet. It is definately not leaking from there.
I suspect it is leaking from inside the workings of the toilet or the toilet bowl. I don't see any cracks. The toilet is aprox 10 years old.
Does anyone have any suggestions? Is it fixable or just cheaper to hire someone to replace the entire machine?
Leaking just at the base a little where the toilet meets the tile in the front area:http://img.photobucket.com/albums/v6...3/IMG_3955.jpgsee the glossy wet area near the tile and toilet?
http://img.photobucket.com/albums/v6...3/IMG_3956.jpg
http://img.photobucket.com/albums/v6...3/IMG_3957.jpg
http://img.photobucket.com/albums/v6...3/IMG_3959.jpg
http://img.photobucket.com/albums/v6...3/IMG_3961.jpg
DangerMouse 04-12-2010 06:50 PM
Hi and welcome.
Does it leak more if you flush it? If so, it's likely your wax ring is not sealing properly.
Good news? An easy and inexpensive fix. Usually only a few dollars. VERY DIYable!
DM
handy man88 04-12-2010 07:13 PM
Can it really be leaking from the wax ring if there's a bead of caulk between the base and the tile floor?
I would check the gasket between the tank and the toilet.
tpolk 04-12-2010 07:18 PM
tank sweating?
DangerMouse 04-12-2010 07:20 PM
Possibly, though a wet backside would be a sure giveaway.
Wiggle the tank gently, if it's loose, you'll know quickly.
Water can seep easily past a silicone caulk line if grout is weak.
DM
CostcoMan 04-12-2010 07:41 PM
The leak does increase a little each time you flush it. So I am thinking it is the the floor to toilet gasket that you speak of.
The two bolt covers that point to the tile are glued on fake. The installer just filled them with caulking and stuck them on. Not sure why. I just pulled them off.
The toilet is bolted towards the wall. I got one loose and waiting till tomorrow on the other. Right now the toilet is caulked so tight everywhere that it won't budge from its place.
fabrk8r 04-12-2010 08:45 PM
CostcoMan...the two bolts you are referring to are what holds the WC (water closet/toilet) to the flange.
Before you try to move the WC shut the water supply off at the angle stop (valve attached to line going to bottom of tank) and remove the supply line from the tank. Then flush the WC to drain the tank. To remove the remaing water from the bowl quickly pour a bucket of about 1-1/2 gallons of water into the bowl...this will force almost all of the water out. Now you can remove the two hold down nuts at the base of the toilet.
There are a lot of good online tutorials about replacing wax rings for DIY.
CostcoMan 04-12-2010 10:00 PM
Thanks fabrk8r and the rest of the posters for the help.
I have to wait until my house guest leave than I am going to try to take a crack at this :)
HooKooDooKu 04-13-2010 11:09 AM
I've once had a leak that seemed like it was the bowl but was actually the tank... more specifically the bolts that hold the tank on the bowl. The leak was running down the back of the bowl where I couldn't see it, but would see it on the floor.
The bolts that hold the tank on the bowl should have some rubber grommits (thick rubber washers) to form a seal. Check to make sure that is not the source of your leak (cheap fix if it is).
I've also fixed a leak where the problem was a warn out rubber seal between the tank and the bowl. Leak only happened when the toilet was flushed... but that one was a little more obvious.
CostcoMan 04-13-2010 12:44 PM
1 Attachment(s)
Thanks HooKooDooKu. I checked all those areas carefully with food dye and say nothing.
I decided to pull up the toilet. Not an easy task with all that careful caulking and tight fit. Looks like my seal to the wall pipe is shot. It feels like a sticky mess of glue right now :(
DangerMouse 04-13-2010 01:30 PM
that sticky 'glue' is what's left of your wax ring.
DM
CostcoMan 04-13-2010 01:47 PM
Oh...hahah..I get it now that I touched it.
How do I get the paint texture to match the wall once the top thin paper dry wall layer has been pulled off? I am trying touch touch up the paint area before I re-install. I already removed all the old painting and caulking from the toilet.
Just having a hard time bringing that wall paint up another .05mm to match the rest of the wall. Thanks
http://img.photobucket.com/albums/v6...3/IMG_3968.jpg
http://img.photobucket.com/albums/v6...3/IMG_3970.jpg
