Cannot Unsolder A Joint - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-04-2005, 05:22 PM   #1
Cannot unsolder a joint
I need to unsolder a joint but am unable to. It is 1/2 copper going into an inline shutoff valve. I need to replace an outside faucet but cannot unsolder it from the inside valve. I am using a propane torch and I have tried heating it for up to 3 - 4 minutes but it will not budge even with gentle persuading with a vice grip. The pipe is horizontal and since the outside valve is open, I assume empty of water. It is about 20 years old. What am I doing wrong?
liteboss is offline   Reply With Quote
Old 10-04-2005, 07:22 PM   #2
Contractor
Sounds to me like not enough heat or residual water in the line. Buy or borrow a MAPP gas torch, you'll never go back to propane.
Teetorbilt is offline   Reply With Quote
Old 10-04-2005, 09:21 PM   #3
Remodeler
MinConst's Avatar
Tettor is right with the Mapp gas. It sure beats propane. Be carefull with it though it is easy to over heat joints with it.
Can't you just cut the pipe and fit up new to what you need?
Minichillo's Construction
I will never leave you hanging!
Web
One Man Shops
MinConst is offline   Reply With Quote
Old 10-05-2005, 08:13 AM   #4
I could just cut it and fit it up. Haven't done a lot of plumbing and I didn't know if this was the "correct" way to do it. Thanks for the replies!
Plaster to drywall joint question. ERIK2173 Remodeling 7 05-16-2009 05:58 PM
Advicce on broken joint on wooden frame of chair markhod Carpentry 2 08-11-2007 09:48 PM
What brand of Joint Compound? mwehnes Building & Construction 6 03-26-2007 08:11 PM
PVC drain pipe leaking at joint, 2 part epoxy last? harleysilo Plumbing 3 09-26-2006 01:29 PM
expansion joint farrington135 Building & Construction 1 01-27-2006 11:02 PM
