Cannot Find Valve For Fridge Line...options? - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-29-2013, 10:56 PM   #1
Cannot find valve for fridge line...options?
Frustrating little problem. I have been in my house about 3 years, fridge came with the house and may be replacing it soon. The house has a finished walk out basement and I think the valve for the fridge line is behind a finished ceiling. So I have a copper line popping up from the floor behind my fridge and no way to turn it off aside from the main house valve
detyianni is offline   Reply With Quote
Old 07-29-2013, 10:58 PM   #2
Forgot to add the rest.
So do I turn off the main and add a valve to the end of the copper tube? If so what kind?
I have a phone line toner, maybe I can use that to try and trace the pipe.
If I knew exactly where the valve was is the ceiling I would just put a hatch
Old 07-29-2013, 11:10 PM   #3
Ok false alarm. After reading other posts on fridge water lines I took a peek under my kitchen sink across the kitchen sure enough there is a valve on the cold water line going into the floor.
That must be it!
Delta shower valve replacement on exterior wall muellertr Plumbing 6 01-02-2013 08:07 AM
A couple furnace gas pipe questions, and an entire plan to replace my gas valve richapple HVAC 13 12-05-2012 12:33 PM
Remove saddle valve for ice maker line? redge03 Plumbing 3 11-17-2011 12:35 PM
in line pressure relief valve hidden 1 Plumbing 2 02-22-2009 05:52 PM
