Can You Use Old Tub With Sterling Tub Surround? - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-06-2010, 08:33 AM   #1
Can you use old tub with Sterling Tub Surround?
I have seen the Sterling Accord tub surround at Lowes that is very strong and durable. However, I don't want to rip out my existing tub. It seems that the Sterling products (Sterling Accord, Sterling Ensamble, etc) work as a kit with tongue and groove like system.
Does anyone have experience with using only the Sterling wall system without using their tub as well?
Blackhawk15108 is offline   Reply With Quote
Old 06-06-2010, 08:38 AM   #2
Most tub surrounds will work, as long as they are properly installed. The main factor should be where the surround meets the tub edge, to eliminate any leaking to get behind it. This is where mold would grow and water can wick into the walls.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 06-10-2010, 07:45 PM   #3
Rewards Points: 152
Call the manufacturer.
Will the surround line up with your existing tub?
I had one manufacturer tell me their surround could be used only with their tub - they wouldn't allow you to file down the "tongue" part of the surround if your tub didn't have grooves in the right place. They said it would void the warranty (if you don't care about that, then go ahead). They also said the edge of the surround needed to line up with the existing tub.
The tub surround I got (which matches with the tub) is quite fragile & the manufacturer (Swan) provides inadequate packaging. If you do go with the surround, be very careful transporting it and installing it. I personally will never use the heavier plastic surrounds again - I will either tile or use the cheaper, thinner plastic ones. HD sent me 3 damaged shower surrounds (each additional shipment taking 2-3 weeks) - given the packaging, it wasn't surprising this happened (HD should be requiring better packaging from suppliers).
lazzlazz is offline   Reply With Quote
Shower Surround & drywall transition mchull Drywall & Plaster 5 08-19-2010 03:31 PM
Tiled Shower Surround Help CluelessNewbie Kitchen & Bath Remodeling 4 02-10-2010 09:33 AM
Gap in Corner Between Tub Surround and Bathtub? Howitzer Remodeling 12 09-17-2008 04:14 PM
Tub surround install issue OriginalSterm Remodeling 4 09-11-2008 07:11 AM
Tub surround shower door issues Zharkov Plumbing 14 06-30-2008 10:52 PM
