Old 09-20-2011, 02:42 AM   #1
Can you use a floor drain for a toilet?
Is a floor drain just a regular drain that runs to the septic? I want to stick a bathroom in my basement. The main drain line runs out the basement wall about a foot off the ground - I was hoping I could tear up the floor and use the floor drain for the toilet.
Should a floor drain be connected to the septic? Is there anything I should do before I rip up the floor? I'm sure I'll have a lot better idea of everything once the floor is up, just don't want to tear up the floor, realize I can't use the drain, then have to re-concrete the floor.
tibberous is offline   Reply With Quote
Old 09-20-2011, 06:49 AM   #2
Super Moderator
Not enough info---
Do you have a septic pit and a sump pit?
Old 09-20-2011, 06:56 AM   #3
Originally Posted by oh'mike View Post
Not enough info---
Almost positive I don't have a sump pit. I thought I just had a septic.
Old 09-20-2011, 07:01 AM   #4
Super Moderator
Septic pits pump the water into the house drains--they also have a second vent pipe---
Sumps pump outside.
Old 09-20-2011, 08:53 AM   #5
In any case, I doubt a floor drain is large enough for a toilet.
Old 09-20-2011, 09:35 AM   #6
A floor drain per se, no. It has a trap not suitable for connecting a toilet to.
A toilet is its own trap and is connected to a drain pipe almost always 3 inches or larger that does not have a trap in it right under the toilet.
The disadvantages of crab apple trees. In summer, the apples are too sour to pick and eat. In winter the birds come and leave dropping all over the place.
Old 09-20-2011, 09:43 AM   #7
call me E
TheEplumber's Avatar
In my area some older houses put their gray water (kitchen, laundry, floor drains) to dry wells, not septics. If yours is like this, you cannot put a toilet on it.
Also, floor drains are piped with 1.5" or 2" drains. A toilet requires a 3" drain
how do i tell what size "rough in" my current toilet is? liverlipsyyz Plumbing 12 07-20-2012 02:39 PM
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 12:19 PM
Toilet wont drain chazlew Plumbing 11 02-27-2011 11:08 PM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 08:52 PM
Toilet jpark Plumbing 18 01-05-2009 08:12 AM
