-   -   Can you use a floor drain for a toilet? (http://www.diychatroom.com/f7/can-you-use-floor-drain-toilet-117778/)
tibberous 09-20-2011 02:42 AM
Is a floor drain just a regular drain that runs to the septic? I want to stick a bathroom in my basement. The main drain line runs out the basement wall about a foot off the ground - I was hoping I could tear up the floor and use the floor drain for the toilet.
Should a floor drain be connected to the septic? Is there anything I should do before I rip up the floor? I'm sure I'll have a lot better idea of everything once the floor is up, just don't want to tear up the floor, realize I can't use the drain, then have to re-concrete the floor.
oh'mike 09-20-2011 06:49 AM
Not enough info---
Do you have a septic pit and a sump pit?
tibberous 09-20-2011 06:56 AM
Originally Posted by oh'mike (Post 732080)
Not enough info---
Almost positive I don't have a sump pit. I thought I just had a septic.
oh'mike 09-20-2011 07:01 AM
Septic pits pump the water into the house drains--they also have a second vent pipe---
Sumps pump outside.
md2lgyk 09-20-2011 08:53 AM
In any case, I doubt a floor drain is large enough for a toilet.
AllanJ 09-20-2011 09:35 AM
A floor drain per se, no. It has a trap not suitable for connecting a toilet to.
A toilet is its own trap and is connected to a drain pipe almost always 3 inches or larger that does not have a trap in it right under the toilet.
TheEplumber 09-20-2011 09:43 AM
199 Attachment(s)
In my area some older houses put their gray water (kitchen, laundry, floor drains) to dry wells, not septics. If yours is like this, you cannot put a toilet on it.
Also, floor drains are piped with 1.5" or 2" drains. A toilet requires a 3" drain
