Can You Tap Into A Basement Floor Drain With A Laundry Tub? - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-28-2011, 12:55 AM   #1
can you tap into a basement floor drain with a laundry tub?
i remodeling our basement and the home was already plumbed with sewerage lines for the bath room. I would like to put in a laundry tub on the opposite side of the basement but the only line that is near to tap is a floor drain. the other issue is that I have a septic system and the line for the rest of the house is 6 feet high off the basement floor.
Mikeeb is offline   Reply With Quote
Old 12-28-2011, 04:44 AM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,228
Where does the floor drain go to if the line to the septic is 6 feet off the floor?
Coastal South Carolina
Old 12-28-2011, 07:37 AM   #3
Civil Engineer
Rewards Points: 4,860
Without details it is impossible to accurately assess your situation. I can tell you that I had a similar situation in my house, in that the laundry drained into the floor drain, which ran out to a drywell, while the sanitary waste went to the septic system via a 4" diameter PVC drain line to the septic tank. This was when I purchased the house in 1991.
None of this met current code. The septic system was replaced, and the laundry drain was connected to the septic drain line. I still have a floor drain in the basement, however it is only used when I mop the floor (this is VERY rare). Certainly in Massachusetts, and probably in most other jurisdictions, it is illegal to run greywater (laundry) directly into the ground, it has to go to the septic system.
The reason for this in my town is that we are all on private water (well), so you are effectively drinking your laundry water, which tends to be high in phosphorus, so it is considered essential that all wastewater be treated via the septic system. Your jurisdiction may have different rules, especially if you are on town water, you need to check with the local board of health or the building inspector. No one on this forum can possibly know your local regulations.
Old 12-28-2011, 11:51 PM   #4
Google sanioflo, they have a system that'll pump up the laundry waste to the over head line.
VIPlumber is offline   Reply With Quote
How to - prevent basement mold crazymountain How To Guides 36 07-23-2014 06:02 PM
Cutting out a concrete basement floor jeffhoward001 Building & Construction 21 01-17-2012 08:51 PM
multiple choice - basement bathroom venting debacle and burps denemante Plumbing 1 11-15-2011 10:50 AM
Plumbing in Basement osajia Plumbing 7 12-08-2010 12:00 PM
Finishing basement laundry room DIYguy2000 Building & Construction 7 12-04-2009 11:56 AM
