Can You Solder Within An Inch Of A Closed Shut Off Valve? - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-15-2012, 08:28 PM   #16
Rewards Points: 320
Yeah, I regret not using type L. I remember reading up on it and one of the sites I read said either M or L was fine for domestic water, but I now know it seems that people disagree with this depending on their local codes/what they know. Seems like L is best, and from now on I will use type L for domestic water.
amodoko is offline   Reply With Quote
Old 08-15-2012, 09:16 PM   #17
Plumber
TheEplumber's Avatar
Rewards Points: 566
L is best and as you said M is often allowed. In your case, you used maybe 18" on a branch line- no problem
The Following User Says Thank You to TheEplumber For This Useful Post:
amodoko (08-16-2012)
Old 08-16-2012, 12:29 AM   #18
Doing it myself
Alan's Avatar
Rewards Points: 2,086
K might actually be "the best"
Whether or not you need your plumbing to last 150 years, I don't know.
Journeyman Plumber
The Following User Says Thank You to Alan For This Useful Post:
repair Mueller 3/4 inch Brass Stop and Waste Valve dadcarter Plumbing 3 03-02-2012 08:27 AM
shut of and drain valve placementin Home Run Heating Vkazman Plumbing 1 02-25-2012 06:54 AM
Where Can I find a 3.5 Inch Flush Valve? limitdiy Plumbing 10 01-10-2012 09:37 PM
Water valve will not shut off smcpherson Appliances 2 05-18-2011 09:55 PM
How to Find and Shut Off the Main Water Valve PUTP Plumbing 16 01-08-2011 09:35 AM
