Can You See Dip Tube From Upper Element Port ? - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-07-2012, 06:51 PM   #1
Rewards Points: 18
Have elec HWH that runs good and hot for about 3 min then gets warmer and stays that way, even for several minutes.
The 2 elements check ok 12.9 ohms, no short to ground. Both TH diagnose test ok. "May" have an upper TH that sticks - diag wil not confirm that.
This WH is about 7 yrs old and in very good shape.
My thinking is that a broken dip tube would cause the water to get cold pretty fast ?
To confirm dip tube problem or not, can it readily be seen from the upper element port with a mini mag lite ?
Thanks for your input.
We Fix Houses is offline   Reply With Quote
Old 11-07-2012, 10:01 PM   #2
Rewards Points: 352
best to pull it out to inspect the whole diptube.
plumberinlaw is offline   Reply With Quote
Old 11-07-2012, 11:52 PM   #3
Doing it myself
Alan's Avatar
Rewards Points: 2,086
I'm confused what the problem is exactly.
Journeyman Plumber
Replace old Knob and Tube with Romex stevefrench Electrical 13 10-04-2012 06:59 AM
Water Heater not heating pepsi3656 Plumbing 2 02-05-2011 12:32 PM
6/3 wire through smurf tube? anygren Electrical 13 08-14-2010 07:23 AM
Brand or OEM element in a water heater? spentonbargains Plumbing 4 10-06-2009 05:01 AM
hot water heater wiring xeluth Electrical 7 09-15-2009 11:11 AM
