Can You See Anything Wrong With This Trap? - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-29-2011, 07:35 PM   #16
Rewards Points: 582
1" dw drain end can bet cut back to hook up to standard dw tail piece..
Old 12-29-2011, 09:50 PM   #17
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Maurice Howden.
Journeyman Plumber
The Following User Says Thank You to Alan For This Useful Post:
oh'mike (12-29-2011)
Old 04-07-2012, 02:56 PM   #18
DIYer
Rewards Points: 244
Is that trap that low (deep) legal for code?
mystic_cobra is offline   Reply With Quote
Old 04-07-2012, 03:39 PM   #19
Homerepairguy's Avatar
Rewards Points: 990
Pete,
Per this photo, your dishwasher drain is below the water level in the trap:
Also, looking at the picture of the top of your sink, I don't see an airgap for the dishwater drain line.
Even if the dishwater drain hose is routed up high in the cabinet, without an air gap in the hose path, waste water from the trap can siphon back into your dishwasher if the check valve went bad. Back siphoning of waste water from the trap into your dishwasher can cause a bad smell but even worse could be a health hazard.
Strongly suggest that you either:
1. Install an air gap in the dishwasher hose line to prevent back siphoning.
-or-
2. Redo the drain plumbing so that the dishwater drain is "above" the level of the water in the trap.
EDIT:
If you do option-2, if you ever have a clogged drain where water backs up into the sink, you will be exposed to back siphoning of waste water back into the dishwasher if you used the dishwasher and the hose got full of water.
So the air gap of option-1 is the much preferred method as it will never allow back siphoning of waste water back into your dishwasher regardless of whether the drain gets clogged.
HRG
Homerepairguy is offline   Reply With Quote
Old 12-30-2012, 11:45 PM   #20
Rewards Points: 154
Just saw this post now. Thanks HRG. I was told that I wouldn't be able to get strainers that were more shallow for this sink...not sure where to go from here and this project has fallen off the plate at the moment.
pete0403 is offline   Reply With Quote
Old 12-31-2012, 12:04 AM   #21
Plumber & Gasfitter
Rewards Points: 77
Step 1: Remove everything from the basket strainers to the piping from under that sink and toss it.
Step 2: Those basket strainers are nothing special, and you should be able to pick up a couple new ones from a local plumbing shop that are more 1/2 circle shaped as opposed to triangular which should give you an extra inch at least.
Step 3: Pick up a 1 1/2" Tee, 90, Union P-Trap, Dishwasher Wye, ABS-Copper Adapter, and (2) Fitting 1 1/2" Trap Adapters.
Step 4: Pipe it similar to how it currently is, with the dishwasher wye where you currently have the fernco fitting. Between the fitting trap adapters and new basket strainers you should be able to lift the running trap arm between the two outlets of the sink atleast 2" higher and you'll have sufficient room to have a properly graded & trapped drainage system beneath your sink.
joeplumber85 is offline   Reply With Quote
The Following User Says Thank You to joeplumber85 For This Useful Post:
pete0403 (01-01-2013)
AC drain pipe vent trap going dry - sewage smell denemante Plumbing 6 04-26-2011 07:52 PM
Drum Trap Replacement RickyBobby Plumbing 4 02-28-2011 07:59 AM
Basement Trap and confused questions Ryan7 Plumbing 15 02-26-2011 11:42 AM
p trap leak after cleaning DIYGST Plumbing 6 12-07-2010 01:17 PM
clogged pipe or trap issue? windowguy Plumbing 3 05-10-2009 11:10 AM
