Can You See Anything Wrong With This Trap? - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-28-2011, 03:49 AM   #1
Rewards Points: 154
Can you see anything wrong with this trap?
Please take a look at these pictures and tell me if you see anything that might cause a bad smell. The old setup didn't have the dishwasher hooked into the drain and had a different sink.
I'm just wndering about small food particles not being able to be flushed down the long trap and rotting on the sink side causing the smell. The sink drains fast, no standing water in the dishwasher.
Thoughts?
pete0403 is offline   Reply With Quote
Old 12-28-2011, 08:02 AM   #2
Retired carpenter
Your drain on the back wall is higher than the connection from the diswasher and seems to be at the same height or slightly higher than the level pipe that comes from the sink on the right. That would make part of the dishwasher hose and that level pipe part of your trap, where water and dishwasher stuff just sits until the next flush.
Your strainer bodies are very deep; if you got smaller ones, you could have all your pipes and connections that are upstream from the trap higher than the drain hole on the wall.
abracaboom is offline   Reply With Quote
The Following 2 Users Say Thank You to abracaboom For This Useful Post:
plummen (12-28-2011), Snav (12-28-2011)
Old 12-28-2011, 08:10 AM   #3
DIY staff
Rewards Points: 7,174
That whole thing is wrong--it filled with sewage all the time.
Open the wall--lower the drain--then repipe under the sink--
Nothing can be done until the drain is lowered.
The Following 2 Users Say Thank You to oh'mike For This Useful Post:
Alan (12-28-2011), Snav (12-28-2011)
Old 12-28-2011, 10:33 AM   #4
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Looks like a MH sink hookup to me. They're always wrong.
Journeyman Plumber
Old 12-28-2011, 12:12 PM   #5
DIY staff
Local code here calls for one p-trap for each sink---I know that is local but I think it makes for a better drain system for a kitchen.
Old 12-28-2011, 02:52 PM   #6
Retired carpenter
I don't see why the OP would have to lower the drain, when he can replumb that mess of pipes to be above the drain by getting shorter (more standard) strainers and skinnier (standard) under-sink pipes.
Old 12-28-2011, 02:56 PM   #7
DIY staff
By the time he adds a tailpiece with a dish washer inlet--he will still be below the drain--
Old 12-28-2011, 03:20 PM   #8
Retired carpenter
The sink to the right isn't as deep as the one on the left. I think he can get that tailpiece there.
Old 12-28-2011, 10:01 PM   #9
Rewards Points: 582
get rid of all the 1 1/2 abs pipe including those deep basket strainers....install new strainers and 1 1/2 tubular piping with d.w tailpeice...even double traps should still room without lowering pipe coming out of wall..
The Following User Says Thank You to ben's plumbing For This Useful Post:
jaydevries (04-07-2012)
Old 12-29-2011, 12:28 AM   #10
DIY staff
Those are the damnedest looking strainers---you guys might be right---His just might make it---worth a try.
Old 12-29-2011, 12:54 AM   #11
Rewards Points: 154
Thanks everyone. I'll try to get some shorter strainers, replace all the piping before the trap with the smaller normal stuff, and move the DW drain to the smaller sink tailpeice.
Two questions about this...first, will the DW drain being right under the strainer be noisy? Right now it makes almost no noise. last, the DW drain rubber end is 1"...can you even get tailpieces with 1" connectors?
??What's "MH"?
Old 12-29-2011, 07:14 AM   #12
DIY staff
Dish washer into the tail piece will make some noise---an acceptable amount---that's standard practice.
'MH' I did not want to look dumb so I didn't ask---Mike---
Old 12-29-2011, 10:26 AM   #13
Master Plumber
Javiles's Avatar
Rewards Points: 986
??What's "MH"?
You could always go with a disposal solves the problem of the D/W tail piece change the one strainer, on the strainer check , if that sink is what I think it is not all standard strainers will work due to the thickness of the sink, electrical if not there should not be a big deal. Good Luck.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 12-29-2011, 02:15 PM   #14
Rewards Points: 1,558
MH=mobile home, I'm guessing?
bob22 is offline   Reply With Quote
Old 12-29-2011, 02:30 PM   #15
jproffer's Avatar
Rewards Points: 706
MH = Mike Holmes???
or maybe mobile home, but what fun is that
jproffer is offline   Reply With Quote
AC drain pipe vent trap going dry - sewage smell denemante Plumbing 6 04-26-2011 07:52 PM
Drum Trap Replacement RickyBobby Plumbing 4 02-28-2011 07:59 AM
Basement Trap and confused questions Ryan7 Plumbing 15 02-26-2011 11:42 AM
p trap leak after cleaning DIYGST Plumbing 6 12-07-2010 01:17 PM
clogged pipe or trap issue? windowguy Plumbing 3 05-10-2009 11:10 AM
