Can You Run Hot Water Line To Toilet? - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-24-2014, 09:32 AM   #1
Rewards Points: 341
Can you run hot water line to toilet?
I have a bathroom on the far side of the house, it doesn't get much use and takes a while for the faucet to warm up. I am wondering if I change the toilet to the hot water line, would it be okay and have the water warm up quicker. I did add pipe insulation, though as it isn't used much it doesn't seem to help all that much. I did see a recirculating pump on Ask This Old House, though that seems overly complicated.
Solaritu is offline   Reply With Quote
Old 06-24-2014, 09:49 AM   #2
Rewards Points: 736
Not sure that would have any effect. Hot water pipes get cold without use, no matter how many things they're hooked up to.
TheBobmanNH is offline   Reply With Quote
Old 06-24-2014, 09:54 AM   #3
Rewards Points: 77
Best thing to do is run your hot water line to something like this, you will have instant hot water. You can run a cold line to it as well, but it will take longer to heat the water once the 2.5 gal has been used up.
http://www.homedepot.com/p/Ariston-2...2-5S/100051412
patented is offline   Reply With Quote
The Following User Says Thank You to patented For This Useful Post:
MTN REMODEL LLC (06-24-2014)
Old 06-24-2014, 09:58 AM   #4
Rewards Points: 12,802
Not going to work and may damage the flush valve.
How do you figure having to flush the toilet every time you want hot water and wasting 5 Gal. of water is going to be any better then running the faucet?
Adding insulation to the pipes may help keep them from freezing but little else.
If your just worryed about the water at the sink a simple point of use water heater under the sink may be what you need.
Old 06-24-2014, 10:50 AM   #5
PoleCat's Avatar
Rewards Points: 1,638
I think it is a superb idea. Based on a scenario where the toilet is used and then hands washed. You're going to be flushing anyway in this case. Hot water will certainly shorten the life of the rubber parts but is more than offset by flushing with what would have been waste water.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
Old 06-24-2014, 11:24 AM   #6
Rewards Points: 384
Remove the insulation, add a heat trace / heat tape cable to the pipe with a heat value of about 3 watts to 7 watts per ft. and put the insulation back on. There, you be done and have an inexpensive electric heater that will last for decades if it is good quality commercial heat tape. Will it be scalding hot? No, but you'll have warm water nearly instantly.
SeniorSitizen is offline   Reply With Quote
Old 06-24-2014, 11:50 AM   #7
Rewards Points: 341
The toilet is a newer style that has a larger tank and takes 3 flushes to empty the tank. I was thinking the standing water in the toilet would cool the hot water. The toilet is located 6 feet away from the sink and I was hoping that using the hot water instead of the cold would save water as I wouldn't be waiting for the water to warm up. The water would go into the toilet instead of down the drain. The bathroom is in the corner of the house that gets colder we seen -15* F in colder times, so I am very hesitant in the colder months to wash my hands in cold water, so I wait for it to warm up. I am looking for a safe and simple solution. I could also stop washing my hands If it gets too complicated, then I guess I would rather wait for it to warm up. The warmer seasons is not a problem, just Jan/Feb. This is a powder room so it is seldom used just to wash hands. Granted I don't know how much it would help if I did this. I know the shower upstairs warms up a lot quicker than the sink next to it, though I know the shower puts out more GPM than a sink or toilet would.
Old 06-24-2014, 12:01 PM   #8
Plumber
TheEplumber's Avatar
Rewards Points: 348
IMO- a recirculation pump under the lav is the best option.
Simple to install and no wasted water. It will also improve hw delivery to the tub/shower
Sent from my HTC6525LVW using diychatroom.com mobile app
The Following User Says Thank You to TheEplumber For This Useful Post:
Solaritu (06-24-2014)
Old 06-24-2014, 12:10 PM   #9
Rewards Points: 275
You generally do not want hot water in the tank or bowl because things will grow faster. I did a service call on my family members rental that had hot to the primary toilet. The renter said it would get dirty very quickly and had major condensation issues.
ct18 is offline   Reply With Quote
The Following User Says Thank You to ct18 For This Useful Post:
Old 06-24-2014, 07:55 PM   #10
Rewards Points: 1,684
That splash effect might be painful.
The Following 3 Users Say Thank You to Ghostmaker For This Useful Post:
keithp (06-25-2014), roofermann (06-25-2014), Solaritu (06-24-2014)
Old 06-24-2014, 09:44 PM   #11
Rewards Points: 341
So after much thought and bouncing it off the experts, I think I will just wait for the water to warm up. While re circulation pump that TheEplumber and Ask this Old House suggested is the best solution, I am thinking for $200 I might be willing to take a few more seconds out of my day in the cold months to let the water warm up
Thanks for all the feedback!
Old 06-25-2014, 11:51 AM   #12
Mold!! Let's kill it!
Rewards Points: 2,012
In some places, hot water is run to toilet tanks to prevent condensation on the outside of the tank, so it's not unheard of. I have doubts whether it will really help you to get hot water to the faucet faster unless you wait until the toilet refills after a flush, and then wash your hands.
Old 06-27-2014, 11:09 AM   #13
Rewards Points: 1,910
It wouldn't even take seconds out of your day if you turn on the faucet as soon as you walk in.
Main Toilet Supply Line Clogged? Redskins-21 Plumbing 10 01-27-2014 06:27 AM
Need Advice on how to Correct Low Water Pressure Joe Tilghman Plumbing 51 04-13-2012 01:11 PM
Toilet Only on Drain Line Perry401 Plumbing 1 09-27-2011 02:30 PM
Toilet jpark Plumbing 18 01-05-2009 08:12 AM
Upstairs toilet pipe noise bliss Plumbing 8 01-10-2008 08:55 AM
