Old 03-17-2008, 06:16 PM   #1
Question
Can you rebuild a shut-off valve?
I have a water shut-off valve mounted on a pipe in between my water meter and my house. This can shut off the water to the whole house, without me going to the sidewalk, and shutting off the main supply. It is a simple valve with the "wagon wheel" style handle that you turn to control the water flow. Water has started to drip out of the valve, where the handle is. The valve is soldered in place to the copper pipe, but it seems to have a nut where the leak is. If I shut the main off, and unscrew that nut, is there some sort of seal that I can replace? An o-ring, or something?
Thanks for your support!!!!
I ask the stupid questions.....but I expect the smart answers.
Wanttodoitright is offline   Reply With Quote
Old 03-17-2008, 06:18 PM   #2
Journeyman Plumber
Ron The Plumber's Avatar
It's leaking through the packing, just try to tighten it up say about 1/4 turn, that will usually stop it from leaking.
Fix it right the first time, so you won't have to fix it a 2nd time.
Ron The Plumber is offline   Reply With Quote
Old 03-17-2008, 07:24 PM   #3
I'll give that a try!
Can the valve be rebuilt, in the event that the previous owner has already tightened it a few times? I don't want to have start cutting pipes and testing my soldering skils.
Old 03-17-2008, 07:26 PM   #4
Journeyman Plumber
No usually, they get replaced when bad, you can add stem packing string if needed, get some at a home center.
Old 03-17-2008, 07:32 PM   #5
Thanks!
I'll give it a shot!
Old 03-18-2008, 03:08 AM   #6
I blame ProWallGuy
Get some stem grease and grease that string before you put it in (assuming its really candle wicking string, and not teflon packing).
Double A is offline   Reply With Quote
Old 03-18-2008, 06:00 PM   #7
Thumbs up
It looks like tightening the nut did the trick!
For now.........
Old 03-19-2008, 09:51 AM   #8
I just had almost the exact same issue last week, except it was the valve that shuts my external tap for my hose off. I went with the string packing and an extra 1/4 turn and for now it seems to be fine.
perpetual98 is offline   Reply With Quote
Sloan flushometer valve won't shut off BradG Plumbing 3 01-24-2008 10:04 AM
Water Valve won't shut off armywife Plumbing 1 12-17-2007 06:16 AM
new install shut off valve leaking ferris84 Plumbing 3 11-12-2007 04:47 PM
Shut off valve trim ring question Jeekinz Plumbing 13 04-11-2007 12:44 PM
dripping from water shut off valve underneath the toilet maitri Plumbing 4 12-10-2006 04:58 PM
