Can You Go From 3/4 In To 1/2 In Back To 3/4 In? - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-07-2012, 12:38 PM   #1
ew1
Can you go from 3/4 in to 1/2 in back to 3/4 in?
The situation is this - I'm putting in an icemaker valve box through an existing hole in the frame - the hole is about 2 in from the wall joist where I'd be mounting the box. I was thinking of using a copper flex pipe designed for water heater connections to connect the valve box to the existing 1/2 inch pipe under the house. But for that to occur, I'd be going from 3/4 inch water service pipe to 1/2 inch pipe that runs to the icemaker T, then back to 3/4 inch for the flex line, and back to 1/2 inch in the valve box.
Should I be worried about cavitation and pitting of pipe due to all that diameter back and forth?
ew1 is offline   Reply With Quote
Old 07-07-2012, 12:47 PM   #2
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Keep in mind that the water heater flex has to be accessible.
They do that kind of thing on mobile homes all the time. It looks very hokey, although i'd say the worst thing that would happen is a plumber would laugh at you if one ever saw it.
Why not just buy some soft copper?
Journeyman Plumber
Old 07-07-2012, 12:53 PM   #3
ew1
You're right - I had already bought the water heater flex line because I wanted the extra sturdyness (I live in a seismically active area), but I think just buying the flexible 1/2 inch is the way to go.
I've only seen the 1/4 inch or 1/8 inch line between the valve box and fridge (outside the drywall), but I've never seen it as part of the piping in the house. Do you think it will hold up if things get jostled around a little bit?
Old 07-07-2012, 03:33 PM   #4
Doing it myself
Alan's Avatar
Back in the 50's and 60's when copper was used, they mostly used flexible copper tubing (type L) to plumb water into houses.
It will be fine. Figure out how much you need, and go buy it from a plumbing shop.
Journeyman Plumber
Old 07-07-2012, 04:13 PM   #5
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,252
If you are saying you are installing an ice maker supply line, all you need is 1/4" flex copper.
Coastal South Carolina
Old 07-08-2012, 09:47 AM   #6
Doing it myself
Alan's Avatar
No, because he's connecting a 1/2" supply to an icemaker valve box, which has a 1/2" inlet.
Journeyman Plumber
Tags
pipe diameter changes
Detached Garage Subpanel + Generator Back Feed insaneirish Electrical 3 09-06-2011 02:09 AM
Built-In (back) Oven Clearance for NM Cable? dcarpen23 Electrical 4 08-29-2011 11:29 PM
Should I paint before I put drywall back up? Dave K Painting 1 05-13-2011 02:25 PM
Re-shaping back yard, tilling and other questions fox_forma Landscaping & Lawn Care 12 03-15-2011 04:51 AM
Proper way to back brush bluefitness Painting 1 02-17-2009 09:34 PM
