Can You Connect A Shower Waste Pipe To Toilet Waste? - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-16-2011, 04:31 PM   #1
Can you connect a shower waste pipe to toilet waste?
I have had my bathroom changed to a wet room recently due to disability. But the plumber has connected the shower waste pipe to the toilet waste. Is this standard practice.
Or will there be a danger of odours coming from the toilet waste to the shower room.
thanks.
microbar is offline   Reply With Quote
Old 05-16-2011, 05:30 PM   #2
Rewards Points: 266
This is standard practice. As long as the shower drain has a p-trap and the systems properly vented you should have no problems. If, on the other hand, you notice an odor coming from the shower drain or gurgling in the drain when the toilet is flushed then you have a problem that needs correcting.
Jim F is offline   Reply With Quote
The Following User Says Thank You to Jim F For This Useful Post:
oh'mike (05-16-2011)
Old 05-16-2011, 07:24 PM   #3
Thanks for your reply Jim F
Is it possible to see if I have a p-trap by unscrewing the plastic drain cover thanks.
Old 05-16-2011, 08:28 PM   #4
Just take sniff around the drain and if you don't have a trap, you will smell the sewer gas.
Old 05-16-2011, 08:28 PM   #5
Just take a sniff around the drain and if you don't have a trap, you will smell the sewer gas.
Old 05-17-2011, 02:43 PM   #6
Here is the details of the drain fitted.
Is this a P-TRAP Thanks.
50mm water seal trapped gully for use with a floor former.
Unique 2 part gully for simplified installation.
Suitable for use with flexible sheet flooring.
Top access gully has a removable inner cup for easy cleaning.
Flow rate in excess of 40 litres per minute.
2" horizontal outlet to BS5255 with 2" x 11/2" solvent weld socket reducer.
Simple to install.
Utilise with a stainless steel adaptor if laying a tiled floor or to complement modern tastes
Old 05-17-2011, 05:22 PM   #7
Rewards Points: 266
Your p-trap would have to be somewhere downstream from that horizontal outlet pipe and would be considered a running p-trap. Is this shower adjacent to a bath tub? If so, it may share the tub trap. If it connects directly to the toilet waste pipe without a trap, it will allow sewage gas up through the shower drain.
Old 05-17-2011, 05:27 PM   #8
I dont think he has installed a running p-trap in the horizontal outlet pipe.
Old 05-17-2011, 08:02 PM   #9
Rewards Points: 266
Call your plumber and ask. If thre is no water seal you will smell stinky gas coming out of the shower drain. Hard to say how your plumber installed this but if he values his reputation he will have installed it properly.
Old 05-17-2011, 08:08 PM   #10
,there looks to be a water seal when I lifted the shower drain cover and I can't smell anything is there a trap built into the diagram I posted.
Old 05-17-2011, 08:36 PM   #11
Plumber
TheEplumber's Avatar
Rewards Points: 440
That drain looks like some sort of bucket trap- not allowed in my area. Do you have more info on it or a brand name?
Old 05-17-2011, 09:15 PM   #12
DIY staff
Rewards Points: 7,174
Where are you located?
Old 05-17-2011, 09:22 PM   #13
Simple to install.
Thats new to me, but I like the look of it. I'm planning to put in a shower in my basement and the trap will be below the slab level.
Being easy to clean would be a plus, in my opinion.
Old 05-17-2011, 09:37 PM   #14
Plumber
Rewards Points: 440
New to me too. Not sure how many inches a 50 mm trap seal is, but you do have a trap so you shouldn't have to worry about sewer gas.
http://www.contour-showers.co.uk/pro...-wastes/tsg52/
Old 05-17-2011, 10:06 PM   #15
Rewards Points: 266
Look at that. Line 1. It does have a trap built into it. The OP is good to go.
toilet flange connection to lead soil pipe rd115 Plumbing 1 11-22-2009 06:37 PM
Pipe knocking when toilet flushed guykovera Plumbing 5 09-27-2008 09:17 PM
Toilet Bowl to Horizontal Waste pipe BOBC Plumbing 3 08-30-2008 02:17 PM
Where is the toilet vent?!?!? domgbrown Plumbing 4 01-11-2008 07:33 PM
Upstairs toilet pipe noise bliss Plumbing 8 01-10-2008 08:55 AM
