Can You Believe A Spider Has The Ability To Break A Waterheater? - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-17-2010, 06:17 PM   #1
Rewards Points: 89
Can you believe a spider has the ability to break a waterheater?
I know that sounds weird, but it true. I worked on two waterheaters that would randomly shut off about once a day. These are the newer style water heaters that have the flamed sealed, and you can see the pilot through the glass. I actually called the manufacturer and they sent me a brand new gas valve. Even after installing the new gas valve, the same problem persisted. Well it turned out that a spider web blocked enough of the air vents on the bottom of the water heater to cause the problem.
To fix the problem, I used a Shop-Vac, and put the vacuum holes so it would be a blower instead of a vacuum. Then I put the vacuum holes on top vent of the waterheater. This blew the air through the waterheater and cleared the vents from the bottom of the waterheater.
I just thought I share this information, because this is one problem that was boggling my mind for about a week. I was ready to replace both of these waterheaters, until somebody suggest this solution. The older water heaters, the ones with the flame exposed and needed to be lite with a match, never had problems like this.
stanlam is offline   Reply With Quote
The Following 2 Users Say Thank You to stanlam For This Useful Post:
Michael Thomas (08-17-2010), oh'mike (08-22-2010)
Old 08-17-2010, 07:02 PM   #2
Chicago, IL
Michael Thomas's Avatar
Interesting. Thanks for posting.
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs http://paragoninspects.com/
Michael Thomas is offline   Reply With Quote
Old 08-21-2010, 09:17 AM   #3
Rewards Points: 150
the newer style gas water heaters are a pain in the ass !
rudolph58 is offline   Reply With Quote
Old 11-10-2010, 03:34 PM   #4
Do it right.
I believe it, gas (natural gas anyways) is extremely low pressure, my gas from my meter is only 6 in/h2o, im sure the WH regulator reduces it even further.
SubSailor is offline   Reply With Quote
Spider mites!!! How often can I use Malathion? proofer Landscaping & Lawn Care 31 11-22-2009 05:38 AM
Delay on Break timers rjbaiad HVAC 6 09-24-2008 05:17 AM
Just can't break sink drain free! DIYtestdummy Plumbing 6 03-05-2008 09:56 AM
