"Can Of Worms" Stack Vent Question - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-11-2010, 05:06 PM   #1
Still going...
ChrisDIY's Avatar
Rewards Points: 508
"Can of Worms" stack vent question
Hello!
Found this vent when I did the demo for the hall bathroom. I was considering doing a skylight but the close proximity to this vent will render that idea moot??? Can a soil stack vent have this angled section? Can I lengthen angled section 10 feet, although major demo to accomplish? Based on an earlier post about a different issue, I thought vents had to connect with the curve going up and not down like in picture.
Need advice, out of sight out of mind...
--Chris the DIY Guy
Working on "The Great Wall of Retaining..."
ChrisDIY is offline   Reply With Quote
Old 09-11-2010, 06:05 PM   #2
Rewards Points: 150
>>>Can a soil stack vent have this angled section? Can I lengthen angled section 10 feet,<<<
The answer to both questions is yes, if thats a dry vent you can do almost anything with it.
The question about the direction of the fitting in the picture is yes it is on backwards
braindead is offline   Reply With Quote
Old 09-12-2010, 08:52 PM   #3
Still going...
ChrisDIY's Avatar
Rewards Points: 508
Thanks! I am going to need to crawl around in that attic space to see if the backwards vent connection is for both the tub, toilet and shower on the opposite wall. Laundry, now a pantry, is the only fixture that could make this a wet vent.
--Chris the DIY Guy
Old 09-13-2010, 05:54 PM   #4
Still going...
ChrisDIY's Avatar
Rewards Points: 508
Well what are the worst type of worms?
The first picture is a panorama my phone created that shows the last connections of the main waste pipe before it turns down and out to the septic system. I have all pipes labeled. The toilet in the hall bathroom is another 4 feet to the left. You can see where it comes across to the main line in the second photo. This toilet has no vent other than the main soil stack vent in the photo to the right. Master vanity has a vent and master toilet might but have not done any demo but in the earlier post with the backward connection toilet is right below that connection. Without even looking up code I know this can't be right. I don't even know where to begin to fix it.
Is that plumbing disaster contest still open?
&quot;Can of Worms&quot; stack vent question-soil-stack.jpg   &quot;Can of Worms&quot; stack vent question-vent.jpg
--Chris the DIY Guy
Old 09-13-2010, 05:56 PM   #5
Still going...
ChrisDIY's Avatar
Rewards Points: 508
Total distance from "hall toilet" to "stack vent" is about 15-18 feet.
Above your head in second photo (post #4) outside of room are connections for kitchen sink and hall vanity which both have a vent.
--Chris the DIY Guy
Old 09-13-2010, 07:08 PM   #6
Still going...
ChrisDIY's Avatar
Rewards Points: 508
Is this an acceptable solution found this picture...
I have very little space in-between the current 3" pipe and the sub-floor. I will have to bring it up the wall and over the top of bathroom and tie into the main vent I need to move up 10 ft.?
--Chris the DIY Guy
Old 09-13-2010, 07:11 PM   #7
Plumber
TheEplumber's Avatar
Rewards Points: 682
In regards to your first photo I'm not so sure it is backwards. Does your vent terminate to the left or right side? even if it is backwards, I wouldn't lose sleep over it. but to change it, cut on the 3 sides and turn it around. Use nohub bands and pvs couplings to reconnect.
I'm still looking at your other pictures- having a hard time following the system but is that a 3x2 santee on it's back at the master vanity? Can't have santees on their back for drainage.
Old 09-13-2010, 07:16 PM   #8
Plumber
Rewards Points: 682
yes it is in my area. we also put lav arms on the 2" vert. vent.
You can lay the 3x2 wye a little flatter too, just keep it above the center line of the 3" wc line
Old 09-13-2010, 09:05 PM   #9
Still going...
ChrisDIY's Avatar
Rewards Points: 508
Looking at it closely the only way I can describe it is a very short, short sanitary tee. The 2" connection is curved but super short and on very top of 3" section.
--Chris the DIY Guy
Old 09-13-2010, 10:37 PM   #10
Still going...
ChrisDIY's Avatar
Rewards Points: 508
But just my luck...a nice air duct to complicate things
--Chris the DIY Guy
Old 09-13-2010, 10:51 PM   #11
Plumber
Rewards Points: 682
roll it to the other side, you can make a surprisingly large hole in those engineered joists. Don't cut into the top/bottom cords though. Contact the joist manufacturer for specs related to hole sizes.
Is there a vent within 6ft of that wc flange?
Old 09-13-2010, 11:08 PM   #12
Still going...
ChrisDIY's Avatar
Rewards Points: 508
I was just in there looking and thought can I do this? Provided a 2" cut out in studs doesn't weaken them too much. Run the 2" up and across to the existing 2" Cut out my 90 degree elbow in my 1-1/2" and bring to a tee. Remove all pieces marked with "X"
--Chris the DIY Guy
Old 12-03-2010, 11:42 AM   #13
Still going...
ChrisDIY's Avatar
Rewards Points: 508
Here's the verdict
Not sure if they were close enough to use the main soil stack as their vent? My new plan will incorporate the proper vents at fixture.
--Chris the DIY Guy
Gas furnace exhaust vent question nowell HVAC 7 01-30-2012 08:31 AM
drawing of studor vent in branch not stack - causing flush issues? ejleonard Plumbing 3 06-30-2009 06:19 PM
Kitchen vent stack uphogger Plumbing 3 06-22-2009 03:54 PM
Can you remove hotwater vent stack? rhino1616 HVAC 1 03-11-2008 08:43 PM
DWV Stack Question dcgray2 Plumbing 9 07-14-2006 12:56 PM
