Old 12-04-2011, 10:12 PM   #1
Question
Can water hammers stop water flow?
I just replaced my water pump and pressure tank. After turning on all the water valves to the house all of the faucets work except the cold and hot water to the tub. Both water lines just before the tub faucet have water hammers on them, about 12" tall by 3/4". Could the water hammers cause an air lock or would it be something else? No other faucets in the house have water hammers.
rj7106 is offline   Reply With Quote
Old 12-04-2011, 10:23 PM   #2
Not going to happen.
Since you changed everthing did you remove the shower head and all the airiators on the sink faucets and flush some water throught the lines? If not the shower head may be pluged up. Worth a try to remove it and see what happens.
The trash could also have stopped up the anti scald valve inside the shower control.
rj7106 (12-04-2011)
Old 12-04-2011, 10:42 PM   #3
Missouri Bound's Avatar
You have a sediment issue.
The Following User Says Thank You to Missouri Bound For This Useful Post:
rj7106 (12-04-2011)
Old 12-04-2011, 10:45 PM   #4
Thumbs up
No shower just a tub, removed all the aerators from all the other faucets and they work fine. Sounds like I'll have to cut an access hole and take out the tub faucet, wouldn't hurt to replace it anyway. Thanks for all your help!!
Old 12-04-2011, 11:39 PM   #5
You can get to the scald valve from the side where the handle are not from the back side in most cases.
rj7106 (12-05-2011)
hot water baseboard flow question (long) fred54 HVAC 4 10-14-2011 04:39 AM
PEX pipe and sharkbite slowing water flow? Snav Plumbing 1 04-09-2010 04:32 PM
How do I adjust hot water limit stop in single handle shower faucet? ThunderCAT Plumbing 2 03-09-2010 03:13 PM
hot water check valve? KE2KB Plumbing 7 01-30-2009 02:36 PM
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 08:32 AM
