Can A Vent Go Higher Than Its Starting Point? - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-25-2009, 09:33 PM   #1
Rewards Points: 174
Can a vent go higher than its starting point?
I am taping into a vent in my basement. The exposed pipe makes a 90 degree turn to the left. There is a plug at the bottom of that 90 degree turn. I was able to unscrew the plug. If I run the vent towards the new bathroom area the pipe will be low and in the way of the storage area behind the bathroom.
I want to tap into the vent and raise it higher so that I dont have the problem that I stated above in the storage area.
My idea was to tap in and put a pvc bushing. Instal a 90 degree elbow to the bushing. Start the run towards the right and immediately use a 45 going up until I can use another 45 at the hight that I want. Is that possible?
Leoskee is offline   Reply With Quote
Old 08-25-2009, 09:46 PM   #2
GC/Master Plumber/Mech
Rewards Points: 560
Can you post a pic?
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
Old 08-25-2009, 09:53 PM   #3
JDC
Plumbing Contractor
JDC's Avatar
Rewards Points: 262
A vent must rise from the fixture all the way out of the house or to where it ties into another vent. It cant rise, fall then rise again which if I'm reading your post correctly, you're wanting to do.
JDC is offline   Reply With Quote
Old 08-25-2009, 09:57 PM   #4
Rewards Points: 560
I was thinking he was using a cleanout to tie into then 45 up and after that little blurry
Any vent must rise a min of 6" above flood level rim before turnig horz
Old 08-26-2009, 08:04 AM   #5
Rewards Points: 174
Here is an outline of what I want to do. The black line represents the current vent. The red is the new PVC that I want to run. The grey line represents the PVC vent at the current height. This height is a problem because where it enters the bathroom it will be in the way of a storage area that I plan to use regularly.
I am not connecting to a clean out. Thats a different project. lol
By the way, keep in mind that this is in the basement. The existing vent runs directly to the roof of the house.
Old 08-26-2009, 08:09 AM   #6
the Musigician
DangerMouse's Avatar
no option to vent it separately?
DM
Old 08-26-2009, 08:35 AM   #7
Rewards Points: 174
No. Id have to run a new vent line to the roof. I asked about those independent vent devices but my town does not allow them.
Old 08-26-2009, 09:21 AM   #8
Chicago, IL
Michael Thomas's Avatar
You can't do that - water will collect at the low point, forming a "trap seal" and preventing the passage of air to vent fixtuers below.
Also, if that's a waste stack, solids will collect there as well.
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs http://paragoninspects.com/
Michael Thomas is offline   Reply With Quote
Old 08-26-2009, 10:32 AM   #9
Rewards Points: 174
Its a regular vent not a waste stack. What water would collect there? Would I be able to put a drain plug at the connection point or something similar?
Any other ideas on how to go about doing this? The default will be to run the grey line in the drawing.
Old 08-26-2009, 09:12 PM   #10
JDC
Plumbing Contractor
JDC's Avatar
Rewards Points: 262
No, you cant do that. A vent must rise from the fixture without sloping down then back up again. It must slope so that it slopes back to a drain. You'll collect water in that trap you made in your diagram from condensation and rain water. You might not collect alot of water all at once, but eventually you will choke off your vent. Since your doesnt allow air admittance valves I'm assuming you're having it inspected. An inspector wouldnt let that arrangement pass either.
Old 08-27-2009, 06:49 AM   #11
Rewards Points: 174
So 6'4" it shall be. I wish I could use one of those air admittance valves but my town is a pain in the ass.
Thanks for all of the help everyone.
how to build a single phase induction motor sashman Electrical 3 03-31-2011 07:18 AM
Low-Slope Ventilation - Cobra Fascia Vent and Cor-a-Vent Roof-2-Wall vent atulc Roofing/Siding 7 08-22-2008 10:40 PM
low-slope roof and leaky ridge vent downers Roofing/Siding 15 02-21-2008 11:35 PM
Yoke vent for water closet kenlog Plumbing 4 07-13-2007 06:34 PM
Bathroom Vent Not Vented to Outside / Would need to vent through flat roof House_Amuck HVAC 5 03-30-2007 09:57 AM
