Can Someone Suggest A Tub? - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-16-2012, 04:32 PM   #1
Rewards Points: 392
Can Someone Suggest a Tub?
Hi,
I'm about to remodel my main bath. it is a 5' by 8' space and has a tub at the end. Then there is a toilet right next to it and then a small 30" wide vanity.
The current tub is 30" by 60" It is cast iron covered in porcelain. I'm thinking of replacing it with an acrylic tub and tiling over the whole area.
What do people think of the 80lb acrylic tubs vs cast iron? I'm thinking it will be very hard to do cast iron on a remodel.. Getting the old one out will likely be pretty hard too!.
zootjeff is offline   Reply With Quote
Old 12-16-2012, 05:06 PM   #2
DIY staff
Rewards Points: 7,174
I install mostly cast iron tubs---they look great for years--no as difficult to install as you might think
When removing the old tub,I try to remove it whole when ever possible---however,I will smash them into chunks if removing in one piece is not practical.
Old 12-17-2012, 12:21 AM   #3
Special User
Rewards Points: 1,230
You sure it's only 30" wide? Standard size is 32" x 60".
I like Americast steel tubs. Lightweight and durable. I don't care for acrylic, we've always had acrylic kitchen sinks and they're impossible to keep clean. Dunno if a tub would have the same trouble but I'd only tolerate acrylic in a whirlpool tub.
The above post is for entertainment purposes only. Its contents may, and probably will, lead to legal liability and damage or loss of property, life, or limb. Use at your own risk.
tylernt is offline   Reply With Quote
Old 12-17-2012, 07:16 AM   #4
Rewards Points: 3,130
Removing a cast iron tub is quite therapeutic. Just cover it with an old blanket and smack the heck out of it with a sledge hammer.
I agree with tylernt. Acrylic tubs are really hard to keep clean and looking nice. And it only takes one time with the wrong cleanser and they're ugly forever. Plus, an improperly installed one can crack.
Old 12-17-2012, 10:09 PM   #5
Rewards Points: 960
Cast iron is the way to go.
Shouldn't be hard to do. I've installed a lot of them and only had help with two. They are the same size, just heavier.
cleveman is offline   Reply With Quote
The Following User Says Thank You to cleveman For This Useful Post:
oh'mike (12-18-2012)
Old 12-18-2012, 08:55 AM   #6
Roofmaster
Rewards Points: 2,210
I put a Jacuzzi in a framed in area. I screwed a 1/2 inch Lag Hook into the joist above the tub center, and used a chain fall to lower it precisely. Worked very well, and I still have my back. Just a hint. Mine is Acrylic, because of the jets, Long and deep, as I wanted to be able to submerge myself, and I am 255lb. The problem with most tubs is that they are too shallow to even be a tub, IMHO. The old Ball and Claw tubs were real tubs. Not like the garbage today. Remember, the depth is only up to the overflow. I have my Jacuzzi. The other "Tub" is coming out in favor of a tiled shower with a seat.
To answer though, Cast iron wins hands down.
Old 12-18-2012, 09:07 AM   #7
Rewards Points: 186
We put in the el-cheapo sheet metal enameled tub from home depot for 120$ each. One in the old house, and it worked out well enough we're doing it again twice in the new house. You don't HAVE to do acrylic or porcelain, there is an inbetween which is fairly heavy gauge metal covered with enamel. I would say for most people this is fine. The acrylic ones I don't care much for as they tend to flex more over time. Plus once it's installed, it's not a huge difference between cast iron and sheet metal. Long term, sure cast iron is better, but it's also a matter of how heavy the tub is and getting it in place. For my wife and I, the enameled sheet metal tub is cheap and held up fine.
Ocelaris is offline   Reply With Quote
Please suggest pergola design skaranam Building & Construction 4 07-06-2012 11:29 PM
What ceiling would you suggest? ONeal Building & Construction 3 07-20-2011 03:15 PM
Please suggest solution port80 Plumbing 9 01-16-2011 01:44 PM
can anyone suggest a one story humidifier... dbldee20 General DIY Discussions 4 11-06-2010 05:17 PM
please suggest me a heat pump system. caseym HVAC 7 10-10-2007 06:41 PM
