Can Someone Help Me With My Tub Drain? - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-21-2009, 11:30 AM   #1
Can someone help me with my tub drain?
In preparation for installing a fiberglass tub and shower surround, we have removed the old metal tub from my 1960s house. The drain is a little confusing....can anyone help me? Here are pictures: http://www.flickr.com/photos/jddean/4122563796/, http://www.flickr.com/photos/jddean/...n/photostream/, http://www.flickr.com/photos/jddean/...n/photostream/.
Thank you!
Jefficator is offline   Reply With Quote
Old 11-21-2009, 12:54 PM   #2
Thank you!
It looks like the top of the trap, where the old waste/overflow connected to it. You will need to remove the thin-walled brass tube and remove the adapter where it appears to screw into the trap inlet. Then you can use the proper adapter to hook in your new waste/overflow. Personally, I would cut the trap of completely with a grinder and replace the entire trap, since your new tub waste/overflow may not match up with where the trap is now. Make sense?
SJSchafer is offline   Reply With Quote
Tags
bathtub , drain
Furnace leak while running AC unit lbartowski HVAC 3 09-18-2009 01:46 PM
Condensor drain Captflx HVAC 6 08-17-2008 10:19 AM
Wierd Floor Drain "Backup" rawkintrevo Plumbing 9 06-04-2008 07:10 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 03:37 PM
