Can A Shower Share A Vent W/ The Sink? - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-04-2013, 09:13 AM   #1
Coconut Pete's paella!
CoconutPete's Avatar
Rewards Points: 504
Can a shower share a vent w/ the sink?
I have a half bath with a similar setup to this (highlighted in red).
I'm planning on adding a shower while it's gutted (highlighted in blue) - ignore the fact that it's a tub - only pic I could find.
Can the shower share the vent with the sink in this case or does it need to have it's own dedicated vent? The shower will be located across from the sink instead of next to it like in the pic.
The shower drain and the sink drain will be roughly 5' apart.
Can a shower share a vent w/ the sink?-plumbing-diagram.jpg
CoconutPete is offline   Reply With Quote
Old 04-04-2013, 10:15 AM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 806
Yes they can share a vent, however the horizontal shower and lav line need to be 2". The vertical lav drain(wet vent) should be 2" as well. The dry vent may be 1.5"-- based on UPC
Old 04-04-2013, 10:39 AM   #3
Rewards Points: 504
Good info - thanks!
I wasn't sure if the requirement changed from a tub to a shower since the tub lets air in through the overflow.
Venting a sink pump WillK Plumbing 2 12-26-2010 01:21 PM
Do I need seperate vent stacks for basement pump and basement sink? twinfins Plumbing 5 12-07-2010 11:28 PM
New shower venting question jwbr Plumbing 0 11-28-2010 02:05 PM
Removing a shower replacing with sink HuskySkull Plumbing 0 01-17-2010 12:08 PM
AAV or Studor Vent Needed for this Tub and Shower Drain? BillyDIY Plumbing 1 12-16-2008 11:11 PM
