Can A Septict Tank Outlet - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-11-2011, 03:21 PM   #1
Can a septict tank outlet
can a septict tank outlet get clogged shortley after pumping
ccampbell is offline   Reply With Quote
Old 12-11-2011, 03:37 PM   #2
i had the septic tank pumped and i replaced the pipe between the cleanout and the tank. it was dissconected and from the tee and would get plugged with tree roots. i was able to get that fixed. i left the tank lid and the pipe exposed so a plumber could inspect it for leaks. between now and mid november it over flowed once. the fluid level in the tank seems to stay around 7 inches from the top. i want to dig and c if there is a clean out for the outlet side of the tank but im not sure were to digg. its a older house and i dont know if it even has one for that end.
small secondary countertop outlet issue rasz Electrical 8 11-07-2011 04:14 PM
Odd voltages at outlet TJF Electrical 12 11-01-2011 09:13 PM
Generator outlet and propane tank dougp23 Electrical 6 10-25-2011 01:32 AM
Outlet not working, reading "open ground" syren Electrical 3 04-19-2010 04:20 PM
septic tank problems. littles Plumbing 1 02-24-2010 09:30 PM
