Can RV Antifreeze Evaporate? - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-24-2013, 02:51 PM   #1
I have a property in the Seattle area where I want to abandon the house on it and sell the property for the land only. The buyer would than be responsible for demolishing the house. Until that happens I want to keep the water in the toilet from evaporating and releasing sewer gas inside the house. Someone I talked to says a plumber can winterize the sewer system by blowing out the system with air (just as you do on a RV) and filling the water traps with RV antifreeze. If this works, I don't have to worry about the toilets and refilling it with water every few months. Currently there is no one living in the house. The advantage of the above procedure would be that it will be rather inexpensive and if we change our mind later to let someone live in the house (with some work) we can easily put the sink and the toilet back to service. Has anyone used this procedure with success?
rrzrr is offline   Reply With Quote
Old 08-24-2013, 02:56 PM   #2
Rewards Points: 12,808
Should work fine.
Make sure to also add it to the sink and tub drains.
Old 08-24-2013, 04:35 PM   #3
An old Tradesmen
Rewards Points: 6,088
Works fine when they winterize a house around here.
Old 08-24-2013, 05:41 PM   #4
Rewards Points: 582
yep that will work just fine...ben sr
Old 08-24-2013, 11:19 PM   #5
It does evaporate but very slowly. I put about 4 inches in my RV's toilet when I winterize around October and sometimes have to add a little around Feb. But what is down in the pipes never evaporate. It'll also keep seals and whatnot from drying out which is an added plus.
Catdaddyxx is offline   Reply With Quote
The Following User Says Thank You to Catdaddyxx For This Useful Post:
ben's plumbing (08-25-2013)
Old 08-25-2013, 09:47 AM   #6
Bill Kearney
Rewards Points: 1,174
Sure, plenty of seasonally used cabins and houses get the same treatment. As do boats. The important thing to remember is to get ALL of the traps. Every last thing that can collect water. Tub, shower, sinks, toilets are all the typical things. But people sometimes forget the appliances. The lines in and out of washers, dishwashers, some new dryers (steam features) and water heaters all need to be properly drained. Don't forget any pooled water in them either. But given your explanation I'm guessing there won't be any appliances left inside?
wkearney99 is offline   Reply With Quote
Old 08-25-2013, 04:29 PM   #7
Thanks for all your inputs. All of the appliances will stay in the house because they are too old to have any values. If the buyer is not going to demolish the house with everything in it, then I may have to empty it out before the sale is completed.
Old 08-25-2013, 05:41 PM   #8
Bill Kearney
If you haven't looked into already, might the house have salvage value? When we demolished our old place we'd first had it salvaged for materials. Got a nice tax break essentially donating a whole house. They saved quite a bit of material; joists, rafters, wood and sub flooring, ducts and pipes (for metal salvage), windows, cabinets, lights, etc.
Old 08-26-2013, 07:35 AM   #9
Rewards Points: 1,214
Shut off main water valve to house drain all water from toilets(tanks) and fixtures. Don't forget the appliances dishwasher, washing machine, ice maker. Use a pump hook it to a hose bib go around to all fixtures and let them run until pink comes out(the color of RV antifreeze) don't forget the hot water heater drain and winterize. After that go around with a bucket and dump more down the drains, toilets. The reason I say pump it in is when people use air pressure sometimes the water still lies in the low spots when you pump it in it goes every where. depends how big the house is and fixtures on the amount you need. I do a 40 foot RV with about 4 or 5 gallons. Think of a house it's just bigger than an RV maybe 5 to fifteen gallons. It's not to much money to spend to save your pipes and house from freeze ups. I believe RV anti freeze is not to be diluted and used at full strength.
No Warranty Means- If it breaks in half you get to keep both halves.
COLDIRON is offline   Reply With Quote
Old 08-26-2013, 09:12 AM   #10
Rewards Points: 150
If you have any floor drains that tie into sewage, be sure to get them to
romex1220 is offline   Reply With Quote
Old 08-27-2013, 09:32 AM   #11
Rewards Points: 1,002
I don't think your traps would evaporate for a very long time, on the order of months or years
Anti-wingnut is offline   Reply With Quote
How much to replace antifreeze in heating system? nbulko Plumbing 1 10-21-2012 08:26 AM
Antifreeze in a boiler ? american501 HVAC 1 10-16-2009 10:11 PM
antifreeze % for outdoor wood burner timothyhot Plumbing 2 09-07-2009 08:44 PM
