Old 04-24-2011, 02:33 AM   #1
Can Rotary Hammer be used in this case ?
I want to replace the "Iron Pipe Fitting" with a brass one. So I have to remove about 2cm wide and several cm deep of the grout and tile around the Iron Pipe Fitting in order to have enough space to take it off.
What is the best method ? Can I use the Chiseling function of a rotary hammer to chisel off the area around the Iron Pipe Fitting ? Will the vibration of the rotary hammer cause cracking of the entire tile ? Or cause pipe leakage deep inside the wall ?
I look forward to your reply.
Best Regards
jusko is offline   Reply With Quote
Old 04-24-2011, 09:44 AM   #2
Hvac Pro
Yes and yes. Why not do it by hand with a metal chisel (sacrifice it for a few $$) and avoid creating a expensive repair when it leaks later. Pre drill some holes carefully with a masonry bit and regular drill (not hammer type) and hand carve the rest out.
Old 04-24-2011, 09:52 AM   #3
Owner
LateralConcepts's Avatar
What is the piping for and why do you want to replace it?
Brad Penske, Operations Manager - Coeur d'Alene, ID
Lateral
CONCEPTS,LLC - Sewer & Septic Line - Video Inspection, Locating, Consulting
(208) 818-8241
LateralConcepts is offline   Reply With Quote
Old 04-24-2011, 10:25 AM   #4
yuri @ Thanks for your advice. I have a rotary hammer on hand so I want to save some energy and sweat.
LateralConcepts @ The "Iron Pipe Fitting" is the main outlet to a water heater. Over time, the iron fitting will become corroded and rusty. Water flow will then become somewhat restricted. The pipes inside the wall are all brass except the outlet fitting. Hope you understand what I said.
Best Regards
Sledge hammer with fiberglass handle... How indestructible are they? xusword Safety 3 04-14-2011 11:13 PM
DIY fireplace remodel gone awry - impenetrable brick wall shawnad73 Building & Construction 8 08-23-2010 09:52 AM
What size framing hammer? bluefitness Building & Construction 21 01-29-2010 08:00 PM
dremel rotary accessories peter2008 Tools 2 09-11-2008 12:32 AM
Johnson Rotary Laser Clutchcargo Tools 1 12-09-2007 04:18 PM
