Old 06-05-2008, 07:56 AM   #1
Can a p-trap be placed quite some distance from a drain?
I'm creating a standing shower upstairs and don't have a lot of room in the joists for a p-trap without creating a soffit in the ceiling below. I was thinking about directing the drain down through the first floor to a p-trap in the basement where room isn't an issue. Is there any reason this wouldn't be advisable?
jayp is offline   Reply With Quote
Old 06-05-2008, 10:01 AM   #2
Journeyman Plumber
Ron The Plumber's Avatar
The trap according to my code, distance between the drain of fixture to the trap, can't be more then 24" So to answer your question, you can't do that.
Fix it right the first time, so you won't have to fix it a 2nd time.
Ron The Plumber is offline   Reply With Quote
Old 06-05-2008, 10:19 AM   #3
Doing it myself
Alan's Avatar
How do you not have room for a p-trap in the floor joists? Aren't they at least 2x6 ? A p-trap should fit up inside of a 2x6......
Journeyman Plumber
drain trap kadgar Plumbing 8 06-06-2008 10:19 AM
Wierd Floor Drain "Backup" rawkintrevo Plumbing 9 06-04-2008 08:10 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 04:37 PM
brass trap to copper drain? bluebee1314 Plumbing 3 04-02-2007 11:29 PM
tub drain maximum distance redline Plumbing 3 08-19-2006 09:20 AM
