Can A Newbie Move Over A Washing Machine? - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-15-2007, 01:02 AM   #16
jproffer's Avatar
Rewards Points: 716
The vent for a 2" trap can be up to 5 feet away from the trap and be legal. The drain that's there now (hopefully) has a vent tied to it somewhere...what he means is that with any luck it's within ONE foot of the current location, so moving the drain would be as simple as...cutting the existing pipe somewhere then: original---coupler---4 feet of pipe---coupler---original. As long as you're draining 1/4" per foot of run, you're good. You need to find out where the existing vent is first.
jproffer is offline   Reply With Quote
Old 02-15-2007, 05:27 AM   #17
Remodeler
MinConst's Avatar
yummy,
What Ron means is that if you have a 2" drain trap it must be vented within 5' of the trap. A vent is a way of getting air into the drain line so it drains properly. They can be a pipe running through the roof or an air admittance valve. These can be place in the basement and only allow air to come into the pipe and will close if water hits it.
Minichillo's Construction
I will never leave you hanging!
Web
One Man Shops
MinConst is offline   Reply With Quote
Old 02-15-2007, 07:31 AM   #18
Journeyman Plumber
Ron The Plumber's Avatar
Correct, the 2" trap and 2" drain from trap can run up to 5' before it needs to connect to it's vent.
You say laundry tub, most laundry tubs will have a 1-1/2" trap and arm, are you sure what you see is 2"?
If it is 1-1/2" then distance to vent will be shorter, 3'6" according to UPC Code.
Post a picture.
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
FloodSafe Washing Machine Hoses IdahoBob Plumbing 13 10-29-2011 04:23 PM
Hotpoint Washing Machine issue pjpjpjpj Appliances 3 03-07-2008 12:26 PM
Washing machine - hot water supply only? Sosh Plumbing 4 07-11-2007 03:36 PM
External Lint Filter for Washing Machine ? Piney Appliances 2 05-03-2007 11:28 AM
Washing machine drain hose morrisp Plumbing 3 09-01-2006 07:24 PM
