Old 01-25-2011, 12:34 AM   #1
Can a new water supply line be set up like this?
We have a building with a number of apartments. We would like to replace the pipes in one or two aparments while leaving the others alone.
Is there a way to run a new line from the water meter, attach it to the old pipes, but be able to attach new lines to it as well? Would that be more trouble than its worth?
darsunt is offline   Reply With Quote
Old 01-25-2011, 07:51 AM   #2
I suppose you can run as many branches as you want, after the meter.
No Hot Water Supply after Removing R.O. System EZ Gruv Plumbing 2 07-04-2010 11:22 PM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 03:18 PM
water pouring into basement from around water supply line matty8199 Building & Construction 29 12-29-2009 06:07 PM
Very Low Hot Water Pressure. PAS1970 General Discussion 2 02-25-2009 04:01 PM
low hot water pressure angus242 Plumbing 10 01-08-2009 12:41 PM
