Can I Use Unions In A Drain Line? - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-19-2010, 01:19 PM   #1
Can I use unions in a drain line?
I'm in Ontario, Canada ...
I'm working with a drain from a laundry tub. Are there any rules in the plumbing code that say I cannot use a union:
a. Between the fixture and its trap?
b. In the trap arm?
Thanks ..
Guy
GuyBooth is offline   Reply With Quote
Old 07-20-2010, 03:19 AM   #2
Long-Time DIYer
Mike Swearingen's Avatar
A. I'm not a licensed pro plumber.
B. I'm not from Canada.
C. I do not know plumbing code well.
D. I'm just an old DIYer.
E. I know of no reason that someone couldn't use a union in a non-pressurized drain line as long as it didn't leak.
F. Make an anonymous call to your local Building Inspection Department and ask if you want.
G. Go ahead and use the union.
Good luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 07-20-2010, 08:32 AM   #3
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,034
Not sure code wise but the issue I see is most unions are smaller ID than the pipe. Why not use a Fernco type connector? you get full diameter of the pipe and they are code compliant in most areas.
Coastal South Carolina
Old 07-20-2010, 10:30 AM   #4
Doing it myself
Alan's Avatar
Rewards Points: 2,086
All code issues aside, using a tubular tailpiece/trap underneath the sink gives you multiple union points.
Clear that with inspector and you're golden.
We ARE allowed to use these in our area.
Journeyman Plumber
Old 07-20-2010, 11:15 AM   #5
Any joint in a drain line is where it will form a clog. Most piping under a sink has slip-joint connectors with friction type nuts or threaded connector. I have never seen an actual"union"in a drain pipe. Normally would be a Fernco or No-hub coupling.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
The Following User Says Thank You to majakdragon For This Useful Post:
DangerMouse (07-20-2010)
Tags
drain line , plumbing
Can drain vents use the radon line? FTenney Plumbing 3 06-10-2010 07:59 AM
water softener drain line moreira85 Plumbing 6 10-31-2009 01:14 PM
Sewer Drain Issues allenzachary Plumbing 20 03-03-2009 08:09 PM
Water and Drain Line Location Material Tester Plumbing 1 11-27-2007 08:40 PM
Cutting Concrete for drain line Piney Building & Construction 2 12-01-2006 08:42 PM
