Can I Use A Tee Before A P Trap? - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-01-2013, 08:08 PM   #1
Rewards Points: 77
Can I use a Tee before a P trap?
Hi there.
I'm looking to put in a overfill pan to minor leaks. Opposite side of wall is bathtub which has a 1.5" P trap underneth. Can I Tee into that without any issues?
nateo is offline   Reply With Quote
Old 01-01-2013, 08:09 PM   #2
Doing it myself
Alan's Avatar
Rewards Points: 2,086
The only provision I know of that MY local code makes is that a condensate waste discharge line may be tied into the vertical portion of a bathtub overflow pipe.
Journeyman Plumber
The Following User Says Thank You to Alan For This Useful Post:
nateo (01-03-2013)
Old 01-01-2013, 10:57 PM   #3
Master Plumber
Javiles's Avatar
Rewards Points: 990
Originally Posted by nateo View Post
Hi there.
If i understand your question correctly the answer is no.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 01-01-2013, 11:00 PM   #4
Plumber
TheEplumber's Avatar
Rewards Points: 444
Hi there.
What is an "overfill pan to minor leaks"?
The Following User Says Thank You to TheEplumber For This Useful Post:
plummen (01-01-2013)
Old 01-01-2013, 11:02 PM   #5
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Are you talking about a washing machine drain pan?
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 01-02-2013, 09:21 AM   #6
Rewards Points: 77
yes .
Old 01-02-2013, 09:22 AM   #7
Rewards Points: 77
and the reason beimm g?
Old 01-02-2013, 10:23 AM   #8
Master Plumber
Javiles's Avatar
Rewards Points: 990
That would fall under the category of a water heater drip pan. by code these drains can not be piped in to the sanitary system unless via an indirect drain with a self priming trapped line.(your close but no cigar) what do you think would happen if you ended up with a clog in that bathroom branch or the main.but again depending on your location this may not be true to code. under the IPC thats a no no.
should drain in to the green area (yard) if this is not possible then you do have other options that will keep you flood free and within code.
Old 01-02-2013, 10:50 AM   #9
Roofmaster
Rewards Points: 2,172
Hi there.
Either I am still suffering from a bad cold, or what you said makes no sense at all. What in gods name does "I'm looking to put in a overfill pan to minor leaks" mean???????
Did you read what you asked? Do you mean
"I want to install a stand-tube to monitor leaks?"
Old 01-02-2013, 10:54 AM   #10
Master Plumber
Javiles's Avatar
Rewards Points: 990
yes i feel your pain with some of these post. what he want to install is a drip pan for the washing machine same as a water heater drip/safety pan only these are for your washing machines. at least i think thats what he wants.
Old 01-02-2013, 04:52 PM   #11
Rewards Points: 77
"indirect drain"...so like a wash tub or something? hum...Perhaps I could send it down to the one in my basement...That washtub empties out into a basement floor drain. Don't know if it's self priming but it always seems to have water in it. Do you think it likely is self priming?
How does one keep cold air out from the outside?
Old 01-02-2013, 09:06 PM   #12
Doing it myself
Alan's Avatar
Dump it right into the utility sink. Easy. Done.
Journeyman Plumber
plummen (01-02-2013)
Old 01-02-2013, 09:12 PM   #13
up cho bác d?t h*ng,=))
yenpham280 is offline   Reply With Quote
Old 01-03-2013, 12:40 PM   #14
Rewards Points: 77
.thanks just im
i think ill go with this method. im just trying to cstch minor overflow issues and turns out utility sink is not easily reachable.
Furnace condensate drain/trap issue SteveC HVAC 33 12-27-2012 12:46 PM
PVC trap adapter on galvanized trap? dougan Plumbing 2 10-05-2012 07:16 AM
Trane XR90 - Condensate Drane Trap JDWorks HVAC 16 02-07-2012 08:59 PM
kitchen wall drain outlet higher than trap arm Druidia Plumbing 24 10-13-2011 01:39 PM
Cat trap fever radtek General DIY Discussions 13 05-31-2009 07:18 PM
