Can I Use A Tankless Toilet? - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-29-2010, 12:07 PM   #1
Can I use a tankless toilet?
My toilet tank is built into the back of the bathroom sink. To flush the toilet there is a lever on the side of the sink. The toilet outlet is 6" on center away from the wall. I was hoping I could replace it with a tank less?
spangler5641 is offline   Reply With Quote
Old 09-29-2010, 12:36 PM   #2
the Musigician
DangerMouse's Avatar
Most likely not without moving the drain.
Most standard toilets are 12" OC for the drain.
Not sure if the same rules apply to a tankless or not.
DM
Old 09-29-2010, 01:13 PM   #3
Thanks. I'm hoping for an easy fix. I've already had my share of DIY
that starts with changing an outlet & the next thing you know the kitchen is gutted.
Old 09-30-2010, 12:32 PM   #4
When you say "tankless" toilet are you referring to a flush valve toilet you see in commercial buildings? If so, your water system will not be able to handle the required flow for a toilet like this. These toilets have 1" connections and flow the entire 1.6 gallons in 5-7 seconds. Your piping system will not be able to handle it.
The Engineer is offline   Reply With Quote
Old 09-30-2010, 05:34 PM   #5
Also, if the outlet on the toilet is only a 6" rough in you won't find anything that will fit in that space without moving the drain. Even commercial flushometer toilets have a 12" rough in
the_man is offline   Reply With Quote
Toilet issue: Shims, wax, general disarray. dawho1 Plumbing 8 01-23-2010 07:38 PM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 07:52 PM
Leaky toilet drain secutanudu Plumbing 0 08-17-2009 10:14 AM
Toilet jpark Plumbing 18 01-05-2009 07:12 AM
Where is the toilet vent?!?!? domgbrown Plumbing 4 01-11-2008 06:33 PM
