Can I Use An MPT Fitting On This Hot Water Outlet? - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-23-2013, 06:05 PM   #1
Rewards Points: 588
Can I use an MPT fitting on this hot water outlet?
I'm confused. I'm not sure if I should use an MPT fitting on this hot water outlet on a Rheem Marathon water heater. If i'm not supposed to use the MPT fitting, what should I use? The water heater manual says explicitly not to use any pipe sealant on the hot water side.
First pic is fitting. Second pic is hot water outlet on water heater.
Can I use an MPT fitting on this hot water outlet?-untitled.jpg   Can I use an MPT fitting on this hot water outlet?-photo.jpg
noone is offline   Reply With Quote
Old 09-23-2013, 06:29 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 436
The seal appears to be made at the rubber washer in the tank outlet- therefore no sealant needed
Old 09-23-2013, 06:49 PM   #3
Rewards Points: 1,766
You need to use a dialectic adapter first. Your tank should have 2 stainless steel nipples that would fit the bill. Never screw copper into a galvanized tank the joint is eaten out by electrolysis.
Old 09-23-2013, 07:00 PM   #4
Plumber
Rewards Points: 436
He's using a Marathon heater. They are plastic tanks with brass connections molded to the poly tank- and I believe they don't have anode rods either.....
The Following 3 Users Say Thank You to TheEplumber For This Useful Post:
ben's plumbing (09-24-2013), Ghostmaker (09-24-2013), noone (09-25-2013)
Old 09-23-2013, 07:34 PM   #5
Rewards Points: 588
That's right. It's a plastic marathon. Am I good without the stainless nipples?
Old 09-24-2013, 07:16 PM   #6
Getting old didn't catch the marathon. There plastic so no problem.
The Following User Says Thank You to Ghostmaker For This Useful Post:
noone (09-25-2013)
Help! Yellow Hot Water mechetti Plumbing 1 11-01-2012 09:57 PM
back flushing a water line. woodywoodwick Plumbing 5 10-18-2012 05:10 PM
My hot water recirculation system is a disaster Michael Neill Plumbing 9 11-05-2010 12:31 PM
Filling a Cast Iron radiator system insulatorpro HVAC 7 10-07-2008 12:31 AM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 09:36 PM
