Closed Thread
Old 01-17-2009, 06:37 PM   #1
Default Can I unglue PVC 1 1/2 inch pipe?
I need to re-do some 20 year old plumbing which has bent and twisted over the years due to exposure to heat. It's still intact -- the joints are fine -- but it's unsightly. It's all glued -- no threaded joint that I can see. Plan A is to find a straight piece and cut it off there and glue the new plumbing on with a collar (might be wrong terminology) and proceed from there. Plan B would be to unglue the old pipework -- is this possible and how would I go about it? Thanks for your help.
ex-Khobar Andy is offline
Old 01-17-2009, 07:18 PM   #2
Master General ReEngineer
Ayuh,...
No Plan B,.... Cut it out,+ Replace it with New....
Bondo is offline
Old 01-17-2009, 09:27 PM   #3
biggles's Avatar
if you just want to straighten it out get slip couplings and some 90s elbows .every place you hacksaw a coupling goes...it you need to turn it.......if you need to shorten it up......cut in tees.grab a spare lenght when getting the fittings/glue at HD
biggles is offline
Old 01-18-2009, 09:54 AM   #4
I hope you meant its not eye pleasing in general, and not actually warped from heat, that would be some serious heat.
LIVING THE DREAM
DUDE! is offline
Old 01-18-2009, 08:10 PM   #5
Old fart still learning!
Somewhere you will need to push and pull on the final connection. If HD doesn't have them, go to a plumbing store and ask for an EZ Span. They extend several inches from a closed position and tighten up on an o-ring.
I do a lot of repair on irrigation and drain lines and I used to hate working on the middle of a line with a passion. A "T" in the middle of a line is even more trouble and now they make one for that also.
Got to wonder how you got to this problem in the first place. Maybe I've just never heard of PVC getting hot and twisted.
If it's worth doing, it's worth doing right. If you wouldn't put your name on it, it ain't done right!
downunder is offline
Old 01-18-2009, 11:26 PM   #6
WaldenL's Avatar
Unglues just fine... With a saw! :-) PVC glue actually melts the PVC so the joint is basically part of the pipe. Just cut out the parts you don't like and rerun. Just don't do anything silly like run a drain uphill . But I've got to agree with others, melted from heat? Where is it? IN the furnace?
WaldenL is offline
Old 01-20-2009, 07:56 PM   #7
Thanks for your help -- yes, some serious heat. This is not a home application but an industrial one -- used as a pressure equalization pipe for some high pressure steam venting.
Old 01-20-2009, 08:10 PM   #8
we had a boiler problem at work, overheated the water, most of the joints of the pvc drain pipe in the kitchen came undone. Didn't realize it at the time, couldn't understand why the dip in the line and the leaks, at least no one got hurt.
LIVING THE DREAM
DUDE! is offline
Old 11-05-2009, 04:21 AM   #9
I have a 1/2" pvc coupler and a 1/2" pvc pipe GLUED together how do I unglue them? without cutting the fitting off and leaving the straight pipe?? John
RBCC is offline
Old 11-05-2009, 07:59 AM   #10
Please read the previous 8 posts.....you cannot unglue PVC pipe. Cut and replace it.
log_doc_rob is offline
Old 11-05-2009, 10:08 PM   #11
I have had good luck with heat, lots of heat. Start with some dry pine with a hard wood like oak on top. With the fire well lit, swist on the pipe until it is free.
gjp31254 is offline
Old 11-06-2009, 02:53 PM   #12
Irrigation Contractor
Default Fix the problem
First of all, most of us are responding to a problem/thread that was brought up 10 months ago.
But for others that are reading this, if you are not going to fix the problem, you will eventually just have to do the fix again. The pipe is melting for a reason - It was not designed for this purpose. PVC pipe is not designed for heat. I would not want to be in any structure with any plastic pipe holding high pressure steam. Fixing the "unsightly" bent pipe will only result in having to fix it again in the future. This is a life threatening situation. This is something that I would get a professional opinion on. High pressure steam in an industrial application should be treated with a lot of respect.
Know your limits people.
Water Guy is offline
Old 11-06-2009, 04:17 PM   #13
Extreme DIY Homeowner
Scuba_Dave's Avatar
2 different questions by 2 different people
This is why you don't piggyback a question on an older thread
---people tend to read & respond to the original question
DIY Chatroom Moderator
Not a Pro or for hire, I have enough to do on my own house, Just Look !!
http://www.diychatroom.com/f49/house-renovation-ongoing-37438/
Scuba_Dave is offline
Closed Thread
More On This Topic
If you live in a part of the country where the temperature gets down below freezing, you just might run into the problem of having your water or drain pipes freeze. As long as you’re home (and not off vacationing somewhere warm) you can usually fix... Read More »
How a Sprinkler Head Works
How a Sprinkler Head Works by Expert Village
Hi I'm Fernando with Expert Village going over how a sprinkler head actually works and as you can see this sprinkler is connected to the pvc piping. When the pressure comes from the valve which is the water rushes in and fills up the piping it then goes... Read More »
Hi this is Fernando we are here with Expert Village you installation of you water system around hard corners, bends, etc. and for the most parts most the angles are straight but here you could see when we where clearing the trench earlier that this is... Read More »
How to Repair PVC Pipe
How to Repair PVC Pipe by Expert Village
Sometimes you’ll have PVC that’s broken under the ground, especially in an irrigation system. And it’s very simple to fix - it’s very cheap, too. What you need to do is identify where the break is - we’re going to imagine... Read More »
Hi my name is Elliott Kwong on behalf of Expert Village. Today I'm going to teach you how to make a kaleidoscope. Okay so we are going to want to cut our pvc pipe. Here we have a pvc pipe and remember it is about 1.5 inches in diameter. So let's measure... Read More »
4 inch drain pipe econdave Building & Construction 7 06-04-2009 01:57 PM
Venting ponch37300 Plumbing 21 01-16-2009 07:56 PM
Septic/sewer pipe replacement Mendocino Plumbing 4 11-21-2008 07:40 PM
First Furnace Install - Need Some Help Getting Started hartkem HVAC 17 10-11-2008 01:55 PM
Service size pipe 3/4 or 1 inch? kgphoto Plumbing 6 01-29-2008 08:23 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
