Can I Tie The Sink Vent Into The Toilet Vent? - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-11-2008, 02:30 PM   #1
Lightbulb
Can I tie the sink vent into the toilet vent?
I am installing a wall hung sink in my half bath and have to move the plumbing that is coming through the floor and was previously hid inside the vanity into the wall. The sink drain pipe coming through the floor currently has an AAV on it for venting, which I cannot use inside the wall. The room is 9' x 3.5' with a toilet on one end and the sink on the other. I want to move the drain pipe into the wall and vent the sink vent pipe around two corners and tie it to the toilet vent inside the wall. Following is a diagram of the room. (T is toilet, S is sink, and periods are floor)
___________________
I............................I
[T]......................[S]
___________________
I have three questions:
1. Am I thinking about this right?
2. How high above the toilet or sink level do I have to tie into the toilet?
3. Does anyone have any tips or things I should keep in mind or look out for?
domgbrown is offline   Reply With Quote
Old 01-11-2008, 02:33 PM   #2
Building and plumbing
USP45's Avatar
Rewards Points: 150
it has to be higher than 6 inches above the sinks rim, angle it upwards so if water does get into the line it will drain back towards the sink. I would just go above the ceiling, should be fine. But like I said, make sure the vent is tilted towards the sink.
USP45 is offline   Reply With Quote
Old 01-11-2008, 02:38 PM   #3
How would it get water in it? I'm confused as to why I need to angle it. I figure if water somehow got into the vent it would either go down the toilet vent which is also the drain or go down the sink vent which will connect to the drain where the p-trap is. Am I thinking about this wrong?
Old 01-11-2008, 05:07 PM   #4
Send a message via AIM to Marlin
[quote=domgbrown;87588 confused as to why I need to angle it.
I figure if water somehow got into the vent it would either go down the toilet vent which is also the drain or go down the sink vent which will connect to the drain where the p-trap is. [/quote]
You answered your own question. Water flows down hill, you need to pitch the vent lines so that water which gets in them from rain, condensation, and possibly stoppages flows out of the line and doesn't collect in them. That can lead to poor venting and rotted pipes.
What size is the toilet vent line? You can't vent both a toilet and a sink on a 1 1/2in line. If it's two inch you can use it.
As for wrapping it around the wall that's fine, just make sure it starts out 6" higher then the top of the sink and that it pitches back towards the sink.
Marlin is offline   Reply With Quote
Old 01-11-2008, 05:28 PM   #5
thanks
thanks, now I'm trying to find the toilet vent. I posted another topic above this one if you think you can help me out. thanks again.
Did I ruin toilet/vent after installing sink??? nibeck Plumbing 4 09-06-2012 07:07 AM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 07:52 PM
Toilet jpark Plumbing 18 01-05-2009 07:12 AM
sink vent? redline Plumbing 6 03-13-2008 03:32 PM
toilet vent problem? docholaday Plumbing 8 06-21-2007 05:05 PM
