Can I Tie My Basement Sump Into My Septic? - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-22-2008, 12:42 AM   #1
Can I tie my basement sump into my septic?
I just dug up my foundation this weekend, waterproofed it, and installed much-needed weeping tile. My basement had a sump and a pump out, but it was pretty useless without weeping tile - it just evacuated the immediate area but didn't keep the floor dry. Anyways, rather than have a separate pump out for the sump can I tie my sump pump into my septic line with a check valve? I live on 20 acres and my septic system consists of 2 tanks and a pump out about 100 yards into the field. I know you can't do this on a municipal system due to volume, but is there any reason I can't do it with a septic system??
whiskeykid is offline   Reply With Quote
Old 09-22-2008, 12:46 AM   #2
Registered User
Termite's Avatar
I sure would advise against doing what you're considering. The septic is a sensitive system, and the volume of water that you'd put into it in a good rainstorm would likely cause a myriad of problems. Don't do it.
Better advice would be to get that drain as far away from the house (and downhill) as reasonably possible, avoiding the septic field altogether.
Old 09-22-2008, 09:31 AM   #3
Rewards Points: 1,088
Amen to that.
handy man88 is offline   Reply With Quote
Old 09-22-2008, 11:05 AM   #4
Point taken. Thanks guys.
Old 09-24-2008, 09:54 PM   #5
no no no no no
doo-man23@comcast.net is offline   Reply With Quote
Sunlight for a Basement Room prglor Remodeling 1 08-31-2008 05:29 PM
Basement Renovation Project Howdy Electrical 6 03-13-2008 12:07 PM
Sump pit filling with water in dry weather dimitar Building & Construction 13 12-19-2007 12:59 PM
Sub Basement Walkout - Please Help pgs_28 Building & Construction 11 08-12-2007 10:55 PM
