Can I Temporarily Connect My Dishwasher In Utility Room During Kitchen Remodeling? - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-04-2010, 11:23 AM   #1
Can I temporarily connect my dishwasher in utility room during kitchen remodeling?
We'll be remodeling our kitchen and I wanted to temporarily connect the dishwasher in the utility room. Can this be done safely? It would be standing next to our washer and drier and I was thinking about draining it into the same large utility sink where the washer is drained. I assume I will need to put some sort of strainer in the sink to prevent it from being clogged by the debris coming out of the dishwasher. Can the d/w be "freestanding" or do I need to secure it somehow? Thanks.
ilyaz is offline   Reply With Quote
Old 01-04-2010, 11:35 AM   #2
dishwasher should not be freestanding, will fall over when door open. Also need to make sure no access to underneath if children around
Old 01-04-2010, 12:01 PM   #3
Rewards Points: 252
Defintely need to secure it from tipping. You could attach a metal strap to the front of the unit (where it usually attaches to the countertop), and secure the other end to the rear wall (in a stud, not just in the drywall).
I'm also in the middle of a kitchen remodeling. I temporarily have my dishwasher connected directly to where the kitchen sink drain used to be (using a number of couplings to make it happen). No filter for the water, but we're pretty good about rinsing dishes before they go into the unit, so the water should be fairly clear.
If you have children, to tpolk's point, cover up access to the bottom/sides with some plywood or something...
Can I temporarily connect my dishwasher in utility room during kitchen remodeling?-8img_3282.jpg
Itsdanf is offline   Reply With Quote
"pass-through" from kitchen to dining room? scoobz Building & Construction 10 12-25-2007 08:05 AM
Dishwasher placement jkrodger Remodeling 2 08-03-2007 02:32 PM
Adding a chair rail to dining room which is connected to kitchen Bacardi 151 Interior Decorating 7 07-05-2007 03:31 AM
My Kitchen Floor-Problems!!! Please Help!!! Fat b Flooring 3 01-25-2007 03:21 PM
Utility room nightmare sgt809 Flooring 6 07-03-2006 04:27 PM
