Can I Split A Main Drain Vent Stack? -- - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-14-2012, 02:20 AM   #1
Question
Can I split a main drain vent stack? --
Hi Everyone,
I live in Texas. I've got all cast iron plumbing under & throughout my pier & beam house, built in 1955. I am expanding a tiny Jack & Jill bathroom into a large adjoining closet. There is 1 toilet, 1 sink, and 1 shower. This is the only plumbing on this end of the house.
I've torn down the "shared" wall that concealed a 4-5" vent stack that goes straight up from the main drain line (same size) under the house, through the floor, up through the ceiling and terminates above the roof. So now the vent stack is in the middle of the now larger bathroom... and I need to move it to a wall(s) to hide it once more.
Obviously, I will be reworking this vent with PVC, so the OD of the pipe will be smaller than the OD of the original CI pipe in the middle of the room.
I need to relocate this vent to any of the 2x4 bathroom walls (not currently possible with the size of the original pipe). My question:
  1. What is the smallest single vent I can use to properly vent this drain line? There will be no additional plumbing fixtures added to the bathroom.
  2. If I cannot do #1 above (downsize the vent to a size that will fit into a 2x4 wall), can I split this large vent under the house and plumb 2-3 smaller vent stacks to go up through the wall, and then tie them together in the attic to the original roof stack?
Please forgive me if I have ommitted any relevant information. I'll do my best to clear up any issues.
SpinFly is offline   Reply With Quote
Old 08-14-2012, 05:27 AM   #2
DIY staff
Rewards Points: 7,174
You could use a 2" vent for the toilet and another 2" vent for the shower/sink---then merge into a 3" to go through the roof.
Old 08-14-2012, 07:12 AM   #3
everywhere i have did plumbing you were required to have at least one minium 3 inch vent continuous from the main sewer through the roof.
Old 08-14-2012, 09:21 AM   #4
Rewards Points: 1,014
http://www.kingcounty.gov/healthservices/health/ehs/plumbing/unitvalues.aspx
This will give you the fixture value for various size pipes and fixtures. This chart is from King County (Seattle) WA, but is derived from international standards. By my calculations, you could vent your bathroom with 1 1/2" DWV piping. Local codes and considerations could vary. For instance, in many snowy areas, all roof penetrations must be 3" minimum because of internal frosting
Anti-wingnut is offline   Reply With Quote
Old 08-14-2012, 09:51 AM   #5
Rewards Points: 3,130
Do you know which code applies where you live? If its the IRC (as where I live), the toilet does not require a separate vent.
Old 08-14-2012, 10:12 AM   #6
Thread killer
Rewards Points: 272
Our code requires the total venting to be at least half the area as the drain exiting the building and they have to be minimum 3" exiting the roof(frost)
You can have it good, fast or cheap. Pick two.
Canucker is offline   Reply With Quote
Old 08-14-2012, 10:12 AM   #7
Thread killer
Rewards Points: 272
Mine requires this too
Old 08-14-2012, 10:23 AM   #8
For all we know, there is another vent at the other end or the house, which would allow this run to be treated as a branch, and not need a 3" statck at this location
Originally Posted by SpinFly View Post
Hi Everyone,
Old 08-14-2012, 11:14 AM   #9
Thanks for all the responses so far! I will look under the house and see if this main line is vented somewhere else with at least a 3" stack.
Our city abides by the International Plumbing Code.
I'll let you know what I find!
Old 08-14-2012, 02:13 PM   #10
It looks like the other vents in my house are just 2 inch
Anybody have any creative suggestions for concealing a 3 inch vent in a 2 x4 wall? Technically, a 3 inch PVC vent might fit (?), but I'm concerned about compromising the top plate of the wall that the vent would go through....
Thanks everyone!
Old 08-14-2012, 05:28 PM   #11
I would just add some furring strips to the side of the studs to make it wide enough for the 3" PVC.
Old 08-14-2012, 07:56 PM   #12
DIY staff
3" PVC will fit into a 2x4 wall----od 3 1/4"
Old 08-14-2012, 08:12 PM   #13
Yeah, I figured it would fit but it doesn't leave any meat (less than 1/4"; the wall is load-bearing) in the top plate to hold the wall together. I will probably have to add furring strips to the shortest wall in the room.
Unless somebody can suggest a way to tie the top plate of the wall together around the vent stack..?
Old 08-14-2012, 08:41 PM   #14
Rewards Points: 636
you can reduce pipe size according to irc read up on it
http://publicecodes.cyberregs.com/ic...2_9_sec006.htm
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is offline   Reply With Quote
Old 08-15-2012, 10:32 AM   #15
like mike said, 3 inch pipe will fit in a 2/4 wall. the fittings won't tho but furring out to cover the fittings would be minor. if they are only at the top and bottom you could cut a recess in the back of the drywall about 1/4 inch so the drywall will lay flat.
Adding a washer drain to main drain stack.... phantomvs Plumbing 5 07-20-2012 06:39 AM
Overlooked vent for shower, will it still drain? crankcase Plumbing 16 10-05-2011 08:41 AM
AC drain pipe vent trap going dry - sewage smell denemante Plumbing 6 04-26-2011 06:52 PM
Sewage smell from shower drain, trap has water, vent was snaked and was clear clearasmud Plumbing 1 04-24-2011 06:28 AM
Attic Ventilation Question handy man88 Roofing/Siding 10 02-12-2010 10:50 PM
